Section (mm²)
0 mm - 6 mm
Diameter (mm)
Conductors material (Cable)
Conductors Plating (Cable)
Number of conductors
Insulation material
Ground / Shielding
Shielding
TAD KT88-STR
Peter B.
Recomendded!
Edwin P.
Hook-up Wires
Find here all our wiring wires, sold by the meter, to cut, allowing the internal wiring of your devices and DIY projects.
  • Mono conductor
    Mono conductor
    Here you will find all of our single conductor cabling wires, sold by the metre, for the internal wiring of your appliances and DIY projects.
  • Multi conductors
    Multi conductors
    Here you can find all our multi-conductor cabling wires, sold by the metre, for the internal wiring of your appliances and DIY projects.
