LAPP KABEL Olflex HEAT Double flexible conductor 0.75mm² Red
Reference : 13049
1,50 €tax incl.
1,25 € tax excl.
Cables LAPP KABEL Ölflex are recognized for their excellent heat resistance. This model can indeed withstand temperatures of -50 ° C to + 180 ° C.
Its silicone insulation keeps it much more flexible than traditional PVC cables for easy installation problems and establishment in environments where space is limited
This cable contains no halogens.
Characteristics
Typestranded wire ÖLFLEX HEAT 180
Number of cores2
Tension c.a300/500 V
InsulatingSilicone
Conductor Area CSA0.75 mm²
max150°C
min-50°C
Tension test2000 V
Outside diameter6.4 mm
Weight / meter59 g
Diameter (mm)6.4
Number of conductors2
Insulation materialSilicon
ShieldingNo
Section (mm²)0.75
Conductors material (Cable)N/A
Ground / ShieldingNo
