MUNDORF ACW215P-BK/BU ANGELIQUE Wiring Cable
The MUNDORF ACW215P-BK/BU ANGELIQUE is a SolidCore audio wiring cable made of Angelique® copper, offered as a twisted pair of 1.5mm diameter conductors, with a cross-section of 2x 1.767mm².
Reference : 22534
25,90 €tax incl.
21,58 € tax excl.
Cable sold by the meter
Mundorf ACW215P-BK/BU Angelique Single-Strand Copper Wiring Cables 2x1.767mm² Black / Blue
The Mundorf ACW215P-BK/BU Angelique is a SolidCore audio wiring cable made of Angelique® copper, offered as a twisted pair of 1.5mm diameter conductors, with a cross-section of 2x1.767mm². Featuring YI8 PVC insulation and black / blue identification, it is intended in particular for the internal wiring of loudspeakers and electronic equipment, as well as for various audio cable constructions. Its DC resistance of 2x 10mΩ/m and its outer diameter of 2x2.4mm make it a suitable solution for applications requiring a SolidCore conductor with a large cross-section. The cable is rated for a nominal voltage of 300V DC and an operating temperature range between -20°C and +90°C.
Technical Specifications
Product TypeWiring cable
Conductor MaterialCopper
Conductor Diameter2x 1.5mm
Cross-Section2x 1.767mm²
DC Resistance2x 10mOhm/m
Outer Diameter2x 2.4mm
Nominal Voltage300V DC
Operating Temperature-20°C / +90°C
ColorBlack / Blue
PackagingSold by the meter
Diameter (mm)1.5
Number of conductors2
Insulation materialPVC
ShieldingNo
Section (mm²)1.77
Ground / ShieldingNo
MUNDORF ACW215P-BK/BU ANGELIQUE Single Strand Copper Wiring Cable 2x1.767mm² Black / Blue
The MUNDORF ACW215P-BK/BU ANGELIQUE is a SolidCore audio wiring cable made of Angelique® copper, offered as a twisted pair of 1.5mm...
