The MOGAMI 2804 is a speaker cable designed for demanding high-fidelity audio systems, particularly when the amplifier is positioned close to the speakers and a short connection is desired. It features a Dual-Coax structure using Neglex III PCOCC copper (monocrystalline OCC copper) to ensure precise and detailed signal transmission.
Its internal conductor consists of 80 strands of 0.08mm, while the shielding uses 100 strands of 0.08mm Neglex III PCOCC. With its low capacitance of 590pF/m and particularly reduced diameter of 4mm, the 2804 combines a compact design with electrical characteristics suited to high-fidelity applications. It features polypropylene (PP) insulation, a flexible TPE outer jacket, a DC resistance of 50mΩ/m for the internal conductor and 45mΩ/m for the external conductor, as well as a characteristic impedance of 15Ω.
Sold by the meter, in a black finish and without connectors, this cable is manufactured in Japan and is particularly suited to making short speaker cables that prioritize signal precision and transparency.
Technical Specifications
| Specifications | |
| Product Type | Speaker Cable |
| Structure | Dual coaxial |
| Impedance | 15 ohms |
| DC Resistance | 50 mOhm/m (internal conductor) 45 mOhm/m (external conductor) |
| Insulation | PP |
| Capacitance | 590pF/m |
| Shielding | 100 x 0.08mm Neglex III PCOCC |
| Internal Conductor | 80 x 0.08mm Neglex III PCOCC |
| Cable Diameter | 4mm |
| General | |
| Color | Black |
| Package content | Sold by the meter |
| Diameter (mm) | 4.0 |
| Number of conductors | 1 |
| Insulation material | PE |
| Shielding | Yes |
| Section (mm²) | N/A |
| Conductors Plating (Cable) | None |
| Ground / Shielding | Yes |
