MUNDORF MCONNECT Copper Foil Flat Wiring Cable 28x0.07mm 1.96mm²
This flat wire Mundorf will appeal to amateurs chevronés wishing to design cables loudspeakers or for the shielding by sheets of transformers, condensers or simply of boxes.
Reference : 15725
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 15-09-2026.
Câble au mètre
The maximum length delivered in one piece is 10m.
For example, If you order 23m, you will receive 10 + 10 + 3m..
MUNDORF MConnect
Copper Foil Wiring Cable 28x0.07mm 1.96mm²
Mundorf MConnect Fil de câblage plat feuille de Cuivre 70x0.07mm
This Mundorf MConnect flat wire from the German manufacturer's Foil Coil coils offers many possibilities such as the DIY design of flat loudspeaker cables with low impedance and low inductance. It will interest the experienced DIY enthusiast who wants to manufacture high quality custom cables. This wire can also be used as an EMI/RFI shielding plate for transformers, components or chassis to combat eddy effects.
Product typeFlat wiring cable
MaterialOFC Copper (Pureté = 99.9997%) 70µ
Section1.96mm²
Width28mm
Thickness0.07mm
Diameter (mm)N/A
Length (m)Sold by length
Number of conductors1
Insulation materialNone
ShieldingNo
Section (mm²)1.96
Inductance (mh)N/A
Ground / ShieldingNo
This flat wire Mundorf will appeal to amateurs chevronés wishing to design cables loudspeakers or for the shielding by sheets of...
