NEOTECH SOCP-14 Wiring Cable UP-OCC Copper PVC 14AWG Ø 3.5mm
The Neotech SOCP-14 cable is a high quality 14AWG UP-OCC copper cable with PVC insulation. Its design makes it an ideal cable for audio.
Reference : 15132
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 29-09-2026.
NEOTECH SOCP-14
Wiring Cable UP-OCC Pure Copper PVC 14AWG Ø 3.5mm
Neotech SOCP-14 Fil de câblage Cuivre UP-OCC PVC 14AWG Ø 3.3mm
The OCC process allows to obtain a larger and purer crystal, with a purity rate of 99.9998%. This ultra pure copper ensures a cable with low electrical resistivity, higher signal transmission speed and greater resistance to twisting, oxidation and corrosion.
Product typeWiring cable
Conductor section14AWG (2.08mm²)
Conductor diameter1.6mm
Conductor materialUP-OCC Pure Copper
Rating current600V 22A
External diameter3.5mm
Sheath materialPVC
Sheath colorBlue
QuantitySold per meter
Diameter (mm)3.5
Length (m)Sold by length
Number of conductors1
Insulation materialPVC
ShieldingNo
Section (mm²)2.08
Ground / ShieldingNo
2 reviews
Lovely speakers cable,nude in cotton sleeve without external pvc
This review has been posted for NEOTECH SOCP-14 Wiring Cable UP-OCC Copper PVC 14AWG Ø 3.5mm
speaker cable live wire
Very good cable, I removed the PVC insulation and insert it in teflon tube AWG10 and closed it both end . Air has the best dialectic 1.0.
I used in double run for live , gently twisted together every 10cm gap between twist. Than inserted in Helix geometry (coil shape) negative wire ( silver plated twisted 12AWG milspec) and terminated in banana plug. Results Wider sound stage, clear background, No noise from speakers,better instrument separation. Worth the price.
