NEOTECH STDCT-14 Hook-Up Wiring Multi-Strands UP-OCC PTFE 2mm²
The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient internal wiring.
Reference : 13360
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 16-10-2025.
Neotech STDCT-14
Hook-Up Wiring Multi-Strands UP-OCC PTFE 2.08mm²
Neotech STDCT-18 Fil de Câblage Multi Brins UP-OCC PTFE 0.823mm²
Neotech has long been the leader in cable production using UP-OCC "single crystal" Copper developed by Professor Ohno of the Chiba Institute of Technology in Japan.
The UP-OCC is 99.99998% pure and is considered to be the "ultimate" conductor used to date. This STDCT-14 cable has a cross-section of 2.08mm² (14AWG) and consists of 19 wires of 0.38mm diameter.
Product typeWiring cable
ConductorUP-OCC Copper (Purity: 99.99998%)
Section2.08mm² (14AWG)
Strands number19 strands of Ø 0.38mm
InsulationPTFE
Internal diameter1.58mm
External diameter2.85mm
Voltage / Current600V 23A
ColorRed
Diameter (mm)2.9
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)2.08
Ground / ShieldingNo
4 reviews
Toujours Excellent !
Ce câble est simplement un : 'assurance tout-risques' !
Utilisé en câblage Filtres HP Médium/Aigu dans du très haut rendement = c'est tout simplement excellent ! Sans parler du rapport qualité//prix, Irréprochable : c'est LE câble qui sonne sans artifice /rajout dès les premières minutes, cependant après une dizaine/vingtaine d'heures et c'est encore mieux !
Merci AUDIOPHONICS pour ce genre de genre de bon/excellent plan.
This review has been posted for NEOTECH STDCT-14 Hook-Up Wiring Multi-Strands UP-OCC PTFE 2mm²
ho rifatto totalmente il cablaggio interno delle mie Magneplanar3.6 insieme i crossover. Che dire,suono pieno e dettagliato naturalezza e profondità d'immagine pazzesca.
Câblage intérieur ampli
Avec se câble j'ai recablé la section sélection hp sortie bornier de mon amplis vintage . Le son est un peu plus transparent mais surtout les infrabasse se ressente mieux . Je conseille néanmoins un diamètre un petit peu inferieur pour plus de faciliter au montage
remplacement cable interieur enceinte LB diatone
bonjour j'ai change mon cable interne avec ce cable neotech,l'enceinte a encore gagné en qualité de son.je le conseille sans pbs.
The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient...
