Even in the field of horn speaker systems, the CELESTION range offers interesting alternatives with excellent technical properties.
Horn motor, 100 W MAX , 8 Ω
1 "horn motor with standard mounting 2 or 3 screws, neodymium motor system in new design, cooling, low weight, compact dimensions Very linear frequency response, very high efficiency for very low distortion: the acoustic values indicated result from the combination with the MRH-200 horn. From 3000 Hz approximately, applications in 2-way systems or even with low 15 "are possible with this engine.
| Speakers | |
| Impedance (Z) | 8 Ω |
| Resonance frequency (fs) | 1750 Hz |
| Maximum bandwidth | fx-19000 Hz |
| Crowds. cutoff (fmax.) (12dB / oct.) | 3000 Hz |
| Maximum power | 100 W MAX |
| Rated power (P) | 50 W RMS |
| Pressure sound. (1W / 1m) | 110 dB |
| Angle dispersion (green / hor) | according to flag |
| Coil diameter | 34.4 mm |
| Magnet diameter | 75 mm |
| cutting | according to flag |
| Mounting depth | according to flag |
| Dimensions | Ø 75 mm x 75 mm |
| Weight | 450 g |
| Speaker Power (W RMS) | 50.0 |
| Speaker Type | Horn loudspeaker |
| Impedance (Ω) | 8 |
| Loudspeaker diameter (mm) | 25.0 |
