MONACOR MHD-152 Horn Speaker High Midrange 60W 8 Ohm Ø2.5cm
Reference : 1522
135,00 €tax incl.
112,50 € tax excl.
8 Ω Horn-Amp High-Pitch Speaker
Pavilion in cast aluminum of classic shape, excellent transmission properties, for universal use. Replacement mobile reel MHD-152 / VC available as an option.
Klang + Ton 01/2003
"With the MHD-152, we've created another loudspeaker at a very attractive price, it's capable of asserting itself among more expensive competitors.
Impedance (Z) 8 Ω
Resonance frequency (fs) 1500 Hz
Maximum bandwidth fx-20 kHz
Crowds. cutoff (fmax.) (12dB / oct.) 2000 Hz
Maximum power 150 WMAX
Nominal power (P) 75 WRMS
Pressure sound. (1W / 1m) 105 dB
Angle dispersion (green / sun) 40 ° / 90 °
Coil diameter 34.5 mm
Magnet diameter 80 mm
cutting 237 x 83 mm
Mounting depth 220 mm
dimensions 268 x 112 mm
Weight 1.2 kg
Speaker Power (W RMS)60.0
Speaker TypeHorn loudspeaker
Impedance (Ω)8
Loudspeaker diameter (mm)25.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)105.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)20000
