MONACOR MRD-120 Ø Horn Speaker Driver 50W 8 Ohm 107dB Ø2.5cm
Compression Monacor MRD-120 1"
Reference : 1516
45,75 €tax excl.
Shipping date: 20-05-2022.
Orders placed before 11AM (GMT+1) will generally be shipped the same day (working day).
Shipping from France
Billing in France
Technical support in France
Motor with horn, 100 W MAX, 8 Ω
With standard 35 mm (1 3/8 ") threads, good linearity of the frequency band and high sound pressure for low distortion: a motor suitable for all types of professional applications, combined with a bass-midrange speaker 38 cm (15 ") or in multi-channel systems. The acoustic values mentioned result from the combination of this loudspeaker with the MRH-120. Replacement mobile reel available as optional MRD-120 / VC.
Impedance (Z) 8 Ω
Resonance frequency (fs) 1300 Hz
Maximum bandwidth fx-17500 Hz
Crowds. cutoff (fmax.) (12dB / oct.) 3000 Hz
Maximum power 100 WMAX
Nominal power (P) 50 WRMS
Pressure sound. (1W / 1m) 107 dB
Angle dispersion (green / sun) 40 ° / 90 °
Coil diameter 34.5 mm
Magnet diameter 120 mm
cutting according to flag
Mounting depth according to flag
dimensions Ø 120 mm x 85 mm
Weight 1.8kg
Speaker Power (W RMS)50.0
Speaker TypeHorn loudspeaker
Impedance (Ω)8
Loudspeaker diameter (mm)25.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)100.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)17500
Colissimo - TNT - SoColissimo
