Connector
Max cable diameter (mm)
Rated current (A)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Button type
Number of positions
Marcus L.
Michael M.
Worth every penny!
mathieu l.
IEC Inlets
Discover our range of IEC plugs of all sizes, for the integration of a power connector on your HiFi devices.
