The IEC C14 Eizz EZ-7030 plug offers a magnificent quality of manufacture, using high performance materials, promoting excellent electrical conductivity and durability. The contacts of the connector are made of tellurium copper with 200µ Palladium/Rhodium plating, the whole maintained by a PTFE insulating body. The contacts allow the assembly of large conductors, up to 3.7mm in diameter. The assembly is very simple with a screw system.
| Specifications | |
| Product type | IEC C14 plug |
| Contacts material | Tellurium copper |
| Contacts plating | Palladium/Rhodium |
| Max conductors diameter | Ø3.7mm |
| Insulation | PTFE |
| Mounting type | To screw |
| Mounting holes spacing | 40mm |
| Color | White |
| Color | White |
| Max cable diameter (mm) | 3.7 |
| Mounting type | To weld |
| Connectic | Male |
| Connector | IEC C14 |
| Contacts Material (Connector) | Tellurium Copper |
| Contacts Plating (Connector) | Palladium |
| Contacts Plating (Connector) | Rhodium |
| Rated current (A) | 10.0 |
