Adapté pour une épaisseur maxi de 1,5 mm. Sinon, bonne connections et qualitatif.
This IEC C14 socket is ideal for integration into a DIY device as a power connector. The socket incorporates an ON/OFF toggle switch for powering your device and a fuse to protect your system.
The fuse is not included. For use with 250V fuses only.
Product type | IEC C14 plug |
ON-OFF switch | |
Fuse holder | |
Color | Black |
Total dimensions | 50*30.6*27.5mm |
Max cable diameter (mm) | N/A |
Mounting type | To weld |
Connectic | Male |
Connector | IEC C14 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
Rated current (A) | 10.0 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
