Presa fantastica, non l ho ancora montato, ma il materiale è di buona qualità. Il fornitore è eccezionale una supporto efficiente, comprerò molto da voi.
IEC C20 3 poles
This IEC C20 (male) socket will allow you to mount your power connectors and connect a cable with IEC C19 (female) connector. The base plate has 3 horizontal poles and is often used by high power devices rather than IEC C13/C14. It supports a voltage and current of 250V AC 16A 50Hz.
| Specifications | |
| Connector type | IEC C20 (male) |
| Poles number | 3 |
| IEC Nominal Voltage / Current | 250V AC 16A 50Hz |
| UL/CSA Nominal Voltage / Current | 250V AC 20A 60Hz |
| Operatig temperature range | -25°C à 70°C |
| Connection type | To solder |
| Spacing between fixation holes | 42mm |
| Total dimensions | 53.5 x 30.2 x 32mm |
| Color | Black |
| Max cable diameter (mm) | N/A |
| Mounting type | To weld |
| Connectic | Male |
| Connector | IEC C20 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | None |
| Rated current (A) | 16.0 |
| Rated current (A) | 20.0 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
