This standard IEC C14 power supply socket incorporates an illuminated toggle switch. It allows mounting on a device panel to set up a power supply input with power-on switching.
Product type | IEC C14 power plug with lighted toggle switch |
Connector | IEC C14 |
Voltage / Current | 250V 10A |
Connector body material | ABS |
Mounting holes spacing | 50mm |
Cutout dimensions | 42*27mm |
Depth | 27.5mm |
Total dimensions | 60*30*32mm |
Connector body color | Black |
Light indicator color | Red |
Max cable diameter (mm) | N/A |
Mounting type | To weld |
Connectic | Male |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | None |
Rated current (A) | 10.0 |
