Expédition rapide, livraison tout aussi rapide — c’est parfait !
Le 7Hz Timeless II est exactement à la hauteur de mes attentes : le son planar magnetic est d’un confort et d’une fluidité incomparables.
The 7HZ Timeless II in-ear monitors, an evolution of the brand's Timeless range, are planar-magnetic IEMs featuring a new 14.5mm diameter driver. This driver is itself driven by two arrays of N52 magnets, offering a high level of response for exceptional dynamics. The 7HZ Timeless II are also easy to drive, thanks to their 15.2 ohm impedance and 108dB sensitivity. In addition, their extended frequency response from 5Hz to 40kHz ensures rich, detailed reproduction. Added to this are numerous improvements such as the possibility of using filter tips for precise adjustment of the frequency curve, and a new, more optimal acoustic cavity. Finally, a high-end audiophile cable with interchangeable termination lets you choose between a 3.5mm jack and a balanced 4.4mm jack. Earphones are connected via 0.78mm CIEM connectors.
The 7HZ Timeless II in-ear monitor features a new planar magnetic driver measuring no less than 14.5mm in diameter. The driver features a dual-sided silver alloy coating just a few microns thick. In addition, a network of N52 magnets drives the whole system, offering a superior level of rendering.
The 7HZ Timeless II feature 3 nozzles for adjusting the sound quality of the IEMs. Derived from the concept of phase plugs for loudspeakers, they provide precise adjustment, enabling the earphones to be adapted to an eclectic music library.
The new Timeless II acoustic cavity features a 7-layer design with double venting and a more secure locking system for the driver. This locking system gives the driver greater stability for improved durability and rigidity.
The 7HZ Timeless II cable features 4 ultra-pure 7N single-crystal copper conductors. Furthermore, it features 0.78mm CIEM connectors on the headphone side and interchangeable 3.5mm or balanced 4.4mm jack termination.
| Specifications | |
| Product type | In ear monitors |
| Speakers type | Planar magnetic |
| Driver diameter | Ø14.5mm |
| Impedance | 15.2 ohms |
| Sensitivity | 108db/V @ 1KHz |
| THD | < 0.2%/1KHz |
| Frequency response | 5Hz-40KHz |
| IEM connectors | CIEM 0.78mmm |
| Cable terminaison | Interchangeable 3.5mm jack / 4.4mm jack |
| Cable conductors | Single-crystal pure copper |
| General | |
| Color | Black |
| Weight | 5g/earphone |
| Package | 1x Timeless II 7HZ in-ear monitors 1x CIEM 0.78mm detachable cable to interchangeable termination 1x 3.5mm jack termination 1x 4.4mm jack termination 3x Filter tips 10x Pair of ear tips 1x Storage box |
| Color | Black |
| Impedance (Ω) | 15.2 |
| Efficiency / Sensitivity (dB) | 108 |
| Lowest frequency (Hz) | 5 |
| Highest frequency (Hz) | 40000 |
| Wireless | No |
| Cable termination | Jack 4.4mm |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | CIEM |
| Phone call feature | No |
| Noise reduction | No |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Yuan Z.
Michael S.
