AUNE IR300 In-Ear Monitors IEM
The Aune IR300 are audiophile in-ear monitors designed to deliver precise, immersive, and customizable sound reproduction. They rely on a crystal-reinforced diaphragm that ensures rigidity and lightness for detailed sound reproduction and excellent transient response. Their symmetrical driver system optimizes diaphragm movement stability, reducing distortion and improving coherence across the entire frequency spectrum.
Reference : 21536
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 19-11-2026.
Aune IR300 Dynamic In-Ear Monitors 32 ohm 121dB 5Hz-40kHz
Photo of Aune IR300
The IR300 also feature a 3x2 tuning system, allowing users to adjust the sound signature according to listening preferences. The precision acoustic chamber promotes a wide soundstage and natural timbre reproduction. Finally, they come with a high-quality audiophile cable featuring interchangeable connectors, ensuring broad compatibility and easy adaptation to different audio sources. Designed for demanding audiophiles as well as high-fidelity mobile listening, the IR300 combine acoustic innovation, versatility, and lasting comfort.
Aune IR300: Premium acoustic design
The IR300 incorporate a W-shaped composite diaphragm enriched with silicon-based crystalline particles, engineered to combine structural rigidity with low mass. This design promotes highly transparent highs while maintaining excellent transient responsiveness. Paired with an independent flexible suspension, it delivers deep, dynamic bass capable of reproducing both subtle nuances and powerful impacts.
The symmetrical driver system optimizes magnetic field distribution and improves diaphragm control, resulting in enhanced impulse response and clear reproduction even in complex passages.
The entire assembly is housed in a precision-machined acoustic chamber within a robust metal shell, reducing unwanted resonances and ensuring a stable acoustic environment. Internal damping elements and a carefully engineered decoupled structure guarantee coherent, natural, and controlled sound reproduction.
Aune IR300 premium design
Aune IR300: 6 tuning options for a personalized sound signature
Thanks to a fully mechanical adjustment system, the IR300 provide six distinct sound signatures using three interchangeable nozzles and two acoustic modules. This purely physical approach allows users to tailor the sound to their preferences without electronic processing that could alter the signal. Listeners can prioritize neutrality, enhance bass presence, or emphasize detail while preserving a natural and faithful reproduction.
Aune IR300 tuning options
Aune IR300: Audiophile cable with interchangeable connectors
The supplied cable features a high-end design using ultra-pure OFC copper conductors in a Litz structure, ensuring clean and stable signal transmission while minimizing loss and interference. Its modular connector system allows quick switching between a 3.5mm single-ended termination and a 4.4mm balanced output, ensuring wide compatibility with modern audio sources. Both flexible and durable, the cable is designed for everyday use and adapts equally well to portable listening and stationary audiophile setups.
Aune IR300 cable
Aune IR300 measurements
Technical specifications
Product typeIn-ear monitors
DriverDynamic Ø10mm
Impedance32 ohm
Sensitivity121dB @ 1kHz
Frequency response5Hz-40kHz
THD< 0.03% @ 1kHz
Detachable cable
Cable conductorsOFC copper
Earphone connectorsCIEM 0.78mm
Interchangeable termination3.5mm single-ended jack
4.4mm balanced jack
Cable length1.25m
Weight9.5g/earpiece
Package contents1x Aune IR300
3x Nozzles
2x Tuning modules
7x Pairs of ear tips
1x CIEM 0.78mm cable with interchangeable termination
1x 3.5mm single-ended termination
1x 4.4mm balanced termination
ColorSilver
Impedance (Ω)30
Efficiency / Sensitivity (dB)121.0
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
AUNE IR300 In-Ear Monitor IEM Dynamic 32 Ohms 121dB 5Hz-40kHz
The Aune IR300 are audiophile in-ear monitors designed to deliver precise, immersive, and customizable sound reproduction. They rely on a...
