Kiwi Ears KE4 are hybrid in-ear monitors combining two dynamic drivers and two Balanced Armature drivers, designed to deliver natural, precise and immersive sound reproduction.
The KE4 incorporates a combination of two dynamic 10mm drivers in isobaric low-frequency configuration, delivering deep, controlled bass. These subwoofers are combined with a customized RAB 32257 Balanced Armature transducer for the midrange, ensuring smooth transitions and richly textured vocals. For high frequencies, a Knowles RAD 33518 tweeter is used, delivering clear, detailed highs.
The KE4 offers a balanced sound signature with precise, punchy bass, a slight warmth in the midrange and clear highs. Bass is present without being intrusive, mids are neutral and natural, while highs are well extended without being fatiguing. This combination makes for pleasant listening to a wide variety of musical genres.
The headphones incorporate a 3-way passive filter and three independent acoustic tubes, for precise separation and smooth transition between different frequencies.
The KE4 shells are made of medical-grade resin with a translucent black finish, offering both durability and refined aesthetics. The faceplates feature a brushed aluminum pattern with the stylized Kiwi Ears logo, adding a touch of elegance. Metal nozzles with protective grilles ensure optimum sound diffusion and protection against impurities.
KE4s are designed to hug the ear for optimum wearing comfort, even during long listening sessions. The included silicone tips provide good passive isolation, effectively reducing ambient noise for total immersion in the music.
KE4s come with a detachable 1.2m silver-plated OFC copper cable, featuring 2-pin 0.78mm CIEM connectors and a 3.5mm TRS jack plug, guaranteeing stable signal transmission and compatibility with a wide range of audio devices.
Product type | In-ear monitors |
Configuration | 2DD+2BA (1 Knowles RAD-33518, 1 RAB-32257 custom) |
Sensitivity | 102dB (±1dB) |
Crossover | Crossover 3 way |
Impedance | 28 ohm |
In-ear monitors tip diameter | Ø6mm |
In-ear monitors connectors | CIEM 0.78mm |
Cable end connector | Jack 3.5mm |
Color | Black |
Conditionnement | 1x IEM Kiwi Ears |
Color | Black |
Impedance (Ω) | 28 |
Efficiency / Sensitivity (dB) | 102.0 |
Wireless | No |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
