LETSHUOER DX1 In-Ear Monitors Jack 3.5mm
The LETSHUOER DX1 are in-ear monitors that feature an 11mm dynamic driver coated with aluminum-magnesium alloy nanoparticles. The diaphragm has a diamond pattern structure for dynamic and rich sound reproduction.
Reference : 21369
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 20-11-2026.
Letshuoer DX1 In-Ear Monitor IEM Dynamic Ø11mm Jack 3.5mm 30 Ohms 108dB 20Hz-40kHz
Photo of the LETSHUOER DX1
The Letshuoer DX1 are in-ear monitors that feature an 11mm dynamic driver coated with aluminum-magnesium alloy nanoparticles. The diaphragm has a diamond pattern structure for dynamic and rich sound reproduction. In addition, a 5kHz frequency filter purifies the sound for clearer reproduction and minimizes distortion. Their 30-ohm impedance and 108dB sensitivity make the DX1 easy to drive. They come with a detachable audiophile cable made of 256 strands of silver-plated monocrystalline copper for flawless signal transmission. In terms of connectivity, there are 0.78mm CIEM connectors on the earphones and a 3.5mm jack termination.
Letshuoer DX1: 11mm dynamic driver
The DX1 earphones' dynamic driver features a coating of aluminum-magnesium alloy nanoparticles. This driver offers excellent tone and an immersive, powerful listening experience. All of its components are precision CNC machined. In addition, the speaker benefits from a coaxial positioning mount that effectively improves overall sound quality while enriching detail and limiting distortion.
The LETSHUOER DX1 driver
The structure of the diaphragm of the LETSHUOER DX1
Letshuoer DX1: Diamond Pattern Structure Diaphragm
Taking advantage of its unique characteristics, this configuration precisely adjusts the frequency and amplitude of vibration of the Letshuoer DX1 diaphragm, allowing for more precise control of sound wave propagation. The result is richer sound, a wider dynamic range, and more vivid musical expression.
Letshuoer DX1: high-quality, comfortable earphones
LETSHUOER DX1 notch filter
5kHz notch filter
The DX1 in ear monitors feature a 5kHz notch filter that attenuates certain frequencies to minimize distortion, resulting in greater detail, precision, and clarity during the listening experience. The smooth, clear, and balanced sound also reduces listening fatigue for long listening sessions without discomfort.
LETSHUOER DX1 ergonomics
Durability and comfort
The DX1 features an electroplated stainless steel shell with a smooth, elegant texture and a high-end metallic finish. In addition, the ergonomically designed shape of the shell prevents pressure within the ear canal for extended wearing comfort.
Letshuoer DX1: An audiophile cable
The detachable cable supplied with the DX1 IEMs is a braided, shielded cable made of 256 silver-plated monocrystalline copper conductors. The single-crystal copper wires are woven using the Litz technique and combined with silver-plated shielding to improve conductivity, allowing for more detailed audio signal transmission and an overall balanced improvement in sound quality. In terms of connectivity, there are 0.78mm CIEM connectors on the earphone side and a 3.5mm jack termination.
The LETSHUOER DX1 cable
Product typeIn-ear monitors
TransducerDynamic Ø11mm with aluminum-magnesium alloy nanoparticle coating
Impedance30 ohms
Sensitivity108dB
Frequency response20Hz-40kHz
Shell materialStainless steel
Detachable cable
Conductive cable material256 strands of silver-plated monocrystalline copper
Earphone connectorsCIEM 0.78mm
Cable terminaisonJack 3.5mm
ColorSilver/gold
Package1x Letshuoer DX1 IEM
1x 0.78mm CIEM cable with 3.5mm jack termination
9x Pair of ear tips for in-ear monitors
1x Storage pouch
ColorSilver
ColorGold
Impedance (Ω)30
Efficiency / Sensitivity (dB)108
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
LETSHUOER DX1 In-Ear Monitor IEM Dynamic Ø11mm Jack 3.5mm 30 Ohms 108dB 20Hz-40kHz
The LETSHUOER DX1 are in-ear monitors that feature an 11mm dynamic driver coated with aluminum-magnesium alloy nanoparticles. The diaphragm has a...
