The Letshuoer DX1 are in-ear monitors that feature an 11mm dynamic driver coated with aluminum-magnesium alloy nanoparticles. The diaphragm has a diamond pattern structure for dynamic and rich sound reproduction. In addition, a 5kHz frequency filter purifies the sound for clearer reproduction and minimizes distortion. Their 30-ohm impedance and 108dB sensitivity make the DX1 easy to drive. They come with a detachable audiophile cable made of 256 strands of silver-plated monocrystalline copper for flawless signal transmission. In terms of connectivity, there are 0.78mm CIEM connectors on the earphones and a 4.4mm jack termination.
The DX1 earphones' dynamic driver features a coating of aluminum-magnesium alloy nanoparticles. This driver offers excellent tone and an immersive, powerful listening experience. All of its components are precision CNC machined. In addition, the speaker benefits from a coaxial positioning mount that effectively improves overall sound quality while enriching detail and limiting distortion.
Taking advantage of its unique characteristics, this configuration precisely adjusts the frequency and amplitude of vibration of the Letshuoer DX1 diaphragm, allowing for more precise control of sound wave propagation. The result is richer sound, a wider dynamic range, and more vivid musical expression.
The DX1 in ear monitors feature a 5kHz notch filter that attenuates certain frequencies to minimize distortion, resulting in greater detail, precision, and clarity during the listening experience. The smooth, clear, and balanced sound also reduces listening fatigue for long listening sessions without discomfort.
The DX1 features an electroplated stainless steel shell with a smooth, elegant texture and a high-end metallic finish. In addition, the ergonomically designed shape of the shell prevents pressure within the ear canal for extended wearing comfort.
The detachable cable supplied with the DX1 IEMs is a braided, shielded cable made of 256 silver-plated monocrystalline copper conductors. The single-crystal copper wires are woven using the Litz technique and combined with silver-plated shielding to improve conductivity, allowing for more detailed audio signal transmission and an overall balanced improvement in sound quality. In terms of connectivity, there are 0.78mm CIEM connectors on the earphone side and a 4.4mm jack termination.
| Specifications | |
| Product type | In-ear monitors |
| Transducer | Dynamic Ø11mm with aluminum-magnesium alloy nanoparticle coating |
| Impedance | 30 ohms |
| Sensitivity | 108dB |
| Frequency response | 20Hz-40kHz |
| Shell material | Stainless steel |
| Detachable cable | |
| Conductive cable material | 256 strands of silver-plated monocrystalline copper |
| Earphone connectors | CIEM 0.78mm |
| Cable terminaison | Jack 4.4mm |
| General | |
| Color | Silver/gold |
| Package | 1x Letshuoer DX1 IEM 1x 0.78mm CIEM cable with 4.4mm jack termination 9x Pair of ear tips for in-ear monitors 1x Storage pouch |
| Color | Gold |
| Color | Silver |
| Impedance (Ω) | 30 |
| Efficiency / Sensitivity (dB) | 108 |
| Wireless | No |
| Cable termination | Jack 4.4mm |
| Headphone / Earphone connector | CIEM |
| Phone call feature | No |
| Noise reduction | No |
