FIIO SNOWSKY OAK NANO In-Ear Monitors IEM
The FIIO SNOWSKY OAK NANO are premium single dynamic driver IEM in-ear earphones designed to deliver precise and natural sound reproduction in an elegant form factor.
By buying this product you get 47 loyalty points
Reference : 22252
479,00 €tax incl.
399,17 € tax excl.
Shipping date: 17-11-2026.
FIIO SNOWSKY OAK NANO Dynamic IEM In-Ear Earphones 50 Ohm 112dB 10Hz-40kHz
The FIIO SNOWSKY OAK NANO are premium single dynamic driver IEM in-ear earphones designed to deliver precise and natural sound reproduction in an elegant form factor. Their CNC-machined pure titanium housing is inspired by luxury watchmaking, providing outstanding mechanical rigidity while minimizing unwanted resonances. They feature a 13.8mm dynamic driver with a beryllium-coated diaphragm, paired with a powerful external magnetic circuit delivering a magnetic flux density close to 1.5T, ensuring excellent transient response and an ultra-low rated distortion of just 0.1% at 114dB SPL. The OAK NANO cover a frequency response from 10Hz to 40kHz, feature a 50Ω impedance and a sensitivity of 112dB/mW, making them suitable for use with both audiophile digital audio players and high-performance DAC/headphone amplifiers. Their detachable CIEM 0.78mm cable is made of cryogenically treated (-192°C for over 100 hours) 6N silver-plated monocrystalline copper and comes with interchangeable 3.5mm jack, balanced 4.4mm jack, and USB-C connectors. The latter integrates a BES3001-SP DSP chip supporting PCM up to 32bit / 384kHz as well as an 8-band parametric equalizer (PEQ). The OAK NANO also feature two sets of interchangeable acoustic nozzles for tailoring their sound signature, along with a particularly comprehensive package including 22 pairs of ear tips and a NEST CUBE carrying case.
FIIO SNOWSKY OAK NANO: High-performance 13.8mm Dynamic Driver
The OAK NANO feature a 13.8mm dynamic driver with a beryllium alloy-coated diaphragm, directly derived from the expertise developed for the legendary FIIO FD7. Beryllium is renowned for its extremely low mass, exceptional rigidity, and high propagation speed, offering superior properties compared to aluminum or titanium, helping reduce coloration while improving sound fidelity. Due to the rarity of pure beryllium, FIIO uses a dedicated alloy faithfully reproducing its acoustic characteristics while further reducing diaphragm thickness to fully unlock its potential. This design delivers greater high-frequency extension, faster transient response, extremely low distortion, and highly accurate micro-detail reproduction. The driver is paired with an external magnetic circuit generating a magnetic flux density close to 1.5T, ensuring excellent diaphragm control and a rated distortion of only 0.1% at 114dB SPL. Finally, the Acoustic Prism system optimizes phase coherence and reduces time-domain distortion to deliver a more accurate soundstage, improved instrument separation, and exceptionally detailed sound reproduction.
FIIO SNOWSKY OAK NANO: Audiophile Cable with Interchangeable Connectors
The supplied cable is made of 6N silver-plated monocrystalline copper and undergoes deep cryogenic treatment at -192°C for over 100 hours to relieve internal metal stress and promote optimal signal transmission. Thanks to its rotating locking interchangeable connector system, the OAK NANO come with 3.5mm jack, balanced 4.4mm jack, and USB-C terminations, ensuring broad compatibility with the vast majority of modern audio sources.
FIIO SNOWSKY OAK NANO: Sound Customization and USB-C DSP Connector
The FIIO SNOWSKY OAK NANO come with two sets of interchangeable acoustic nozzles offering two distinct sound signatures, emphasizing either richer bass or a more analytical and detailed high-frequency response. The USB-C connector integrates a BES3001-SP DSP chip supporting PCM decoding up to 32bit / 384kHz as well as an 8-band parametric equalizer (PEQ), allowing users to fine-tune the sound reproduction according to their preferences or the connected earphones.
Technical Specifications
Product TypeIn-ear earphones
DriverDynamic Ø13.8mm
Impedance50Ω @ 1kHz
Sensitivity112dB/mW @ 1kHz
Frequency Response10Hz–40kHz
Detachable Cable
Cable Conductor MaterialSilver-plated monocrystalline copper with cryogenic treatment
Earphone ConnectorCIEM 0.78mm
Cable TerminationInterchangeable:
1x 3.5mm jack
1x Balanced 4.4mm jack
1x USB-C
Cable Length1.2m
DSP
Weight8.9g (without cable)
Package Contents1x FIIO SNOWSKY OAK NANO
1x NEST CUBE Storage Case
1x Detachable CIEM 0.78mm Cable with Interchangeable Termination
1x 3.5mm Jack Termination
1x Balanced 4.4mm Jack Termination
1x USB-C Termination
2x Interchangeable Acoustic Nozzles
2x Foam Ear Tips (M)
3x "Bass" Ear Tips (S/M/L)
3x "Balanced" Ear Tips (S/M/L) (M pre-installed)
3x "Vocal" Ear Tips (S/M/L)
2x Double-Flange Ear Tips (M)
1x Magnetic Cable Clip
1x Cleaning Brush
3x SpinFit Ear Tips (S/M/L)
3x HS18 Ear Tips (S/M/L)
3x HS20 Liquid Silicone Ear Tips (S/M/L)
ColorSilver
Impedance (Ω)50
Efficiency / Sensitivity (dB)112.0
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Cable terminationUSB-C
Phone call featureNo
Noise reductionNo
FIIO SNOWSKY OAK NANO In-Ear Monitors Dynamic IEM 50 Ohm 112dB 10Hz-40kHz
The FIIO SNOWSKY OAK NANO are premium single dynamic driver IEM in-ear earphones designed to deliver precise and natural sound reproduction in an...
