LETSHUOER S15 In-Ear Monitors IEM
The S15 in-ear monitors from Letshuoer are equipped with a third-generation dynamic driver with a diameter of no less than Ø14.8mm, giving them a wide soundstage.
By buying this product you get 28 loyalty points
Reference : 18543
289,00 €tax incl.
240,83 € tax excl.
Shipping date: 24-06-2025.
LETSHUOER S15 Dynamic Planar-Membrane In-Ear Monitors IEM 30Ω 106dB 20Hz-40kHz
Picture of LETSHUOER S15 In-ears monitors
The Letshuoer S15 in-ear monitors are equipped with a third-generation planar magnetic driver with a diameter of no less than Ø14.8mm, giving them a wide soundstage. The S15 are the result of extensive research and technical optimization of planar membranes. Their structure also incorporates a 6mm passive radiator to optimize the driver and provide greater dynamics and transient response. This improves the overall quality of low frequencies and enables more precise sound reproduction.
Exploded view of LETSHUOER S15 In-ear Monitors
Letshuoer S15: An innovative planar membrane
The S15's planar diaphragm makes them ideal for reproducing all styles of music. Thanks to their wide soundstage, they offer a detailed and precise reproduction. The 6mm passive radiator accompanying the planar diaphragm is based on R-Sonic Dynamic Harmonic technology. This passive radiator eliminates low-frequency excess, manages internal acoustic pressure and ensures effective passive resonance.
LETSHUOER S15 Harmonic Dynamic R-Sonic Technology
LETSHUOER S15: filtering system with acoustic tubes
Letshuoer S15: a structure with an acoustic tube filter system
The S15 incorporates a two-tube acoustic crossover system to ensure a smooth transition between bass, midrange and treble. This brings transparency and rich stratification to the sound. The distribution of energy between the planar driver and the passive radiator also reduces distortion.
Letshuoer S15: an optimized acoustic chamber
The S15 acoustic chamber was designed by Letshuoer in collaboration with HeyGears. It meets the highest standards of stability and comfort. The interior is specially designed to provide acoustic stability and a very low level of distortion. In addition, the exterior of the shell is made from a CNC-machined aluminum-magnesium alloy, sandblasted and anodized for a soft, smooth surface.
LETSHUOER S15: acoustic chamber
LETSHUOER S15: cable and termination
Letshuoer S15: audiophile accessories
To ensure perfectly stable transmission of the sound signal, a high-end cable made of 216 strands of silver-plated monocrystalline copper is supplied. Standard CIEM 0.78mm connectors are found on the earphones side, while a termination compatible with 3 tips is found on the other side of the cable. You can choose between the following connectors: 3.5mm jack, 4.4mm jack or 6.35mm jack. All connectors are angled at 90°.
Product typeIn-ear monitors
Speaker typePlanar membrane and passive radiator
Diaphragm diameterØ14.8mm
Shell materialAluminum and magnesium
Impedance30 ohms
Frequency response20Hz - 40kHz
Sensitivity106dB
Earphones connectorsCIEM 0.78mm
Cable conductorSilver-plated single-crystal copper
Interchangeable cable termination1x 3.5mm jack, 90° angled
1x 4.4mm jack, 90° angled
1x 6.35mm jack, 90° angled
ColorBlue and silver
Package1x LETSHUOER S15 in-ear monitors
1x 0.78mm CIEM cable to interchangeable termination
1x Jack 3.5mm 90° angled connector
1x jack 4.4mm 90° angled connector
1x Jack 6.35mm 90° angled connector
1x Storage pouch
ColorBlue
ColorSilver
Impedance (Ω)30
Efficiency / Sensitivity (dB)106.0
Lowest frequency (Hz)20
Highest frequency (Hz)4000
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
The S15 in-ear monitors from Letshuoer are equipped with a third-generation dynamic driver with a diameter of no less than Ø14.8mm,...
