MEZE ALBA Dynamic IEM In-Ear Monitors
With its ALBA in-ear monitors, MEZE presents dynamic IEMs with Ø10.8mm drivers. They feature an extended frequency response of 15Hz-25kHz for a wide soundstage. Their 32-ohm impedance and sound pressure level of 109dB/1mW (32 ohm) make them easy to drive and offer a high level of compatibility, whether for use with a DAP or a headphone amplifier, for example.
Reference : 19475
159,00 €tax incl.
132,50 € tax excl.
MEZE ALBA Dynamic IEM In-Ear Monitors Ø10.8mm 32 Ohm 109dB 15Hz-25kHz
MEZE ALBA picture
With its ALBA in-ear monitors, MEZE presents dynamic IEMs with Ø10.8mm drivers. They feature an extended frequency response of 15Hz-25kHz for a wide soundstage. Their 32-ohm impedance and sound pressure level of 109dB/1mW (32 ohm) make them easy to drive and offer a high level of compatibility, whether for use with a DAP or a headphone amplifier, for example. The ALBAs promise clear, precise sound reproduction thanks to a distortion level of <0.1% (1kHz). A 2x CIEM 0.78mm to 3.5mm jack cable with silver-plated conductors and a 3.5mm to USB-C adapter with integrated DAC/Amp chip complete the package. This adapter supports PCM 32bit 384kHz high-definition streams, enabling you to enjoy audiophile listening with a source such as your smartphone.
MEZE Alba: durable, comfortable earphones
Made from zinc-aluminum alloy, these earphones are very durable, but also lightweight, for a pleasant level of comfort during long listening sessions. Their modern look and white pearl color also make them visually pleasing.
Écouteurs confortables
Les accessoires des MEZE ALBA
MEZE Alba: audiophile accessories
The detachable 2x CIEM 0.78mm to 3.5mm gold-plated cable features silver-plated conductors for high conductivity, as well as corrosion and oxidation resistance for its termination. In addition, a jack 3.5mm female to USB-C male adapter with integrated DAC/Amp chip enables the Meze Alba to receive high-resolution streams up to PCM 32bit 384kHz if you wish to use them with a USB-C smartphone.
MEZE Alba: a distinctive sound signature
The reputation of Meze headphones is well established, but purchasing one requires a certain budget. With the Alba dynamic IEMs, the brand makes its rather neutral, warm sound signature accessible to the widest possible audience. The Alba headphones are a good entry-level product for anyone wishing to benefit from the quality of MEZE products.
Product typeIn-ear Monitors
DriversDynamics
Speakers diameter10.8mm
Impedance32 ohms
Sound pressure level (SPL)109dB/1mW, 32 ohm
THD+N< 0.1% @ 1kHz
CableDetachable cable 2x CIEM 0.78mm to 3.5mm jack termination
Cable conductor platingSilver
Cable length1.20m
3.5mm jack termination platingGold
3.5mm jack to USB-C adapterIntegrated DAC/Amp chip
Weight14g
ColorWhite
Package1x MEZE Alba dynamic IEM
1x Detachable cable 2x 0.76mm CIEM to 3.5mm jack termination
1x 3.5mm jack to USB-C adapter with integrated DAC/Amp
4x Pair of ear tips (S, M, L, XL)
1x Storage pouch
ColorWhite
Impedance (Ω)32
Efficiency / Sensitivity (dB)109
Lowest frequency (Hz)15
Highest frequency (Hz)25000
WirelessNo
Cable terminationUSB-C
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
With its ALBA in-ear monitors, MEZE presents dynamic IEMs with Ø10.8mm...
