By buying this product you get 109 loyalty points
MEZE RAI PENTA In-Ear Monitor IEM 5 Drivers 20 Ohm 110dB 4Hz - 45kHz
" Rai Penta is the culmination of 3 years of researching the most ergonomic shape and most vivid sound for an Universal IEM. We could have released it earlier, but again, like with any of our other products, we wanted to make sure it is truly the best we can achieve. "
Antonio Meze, Lead Designer & Founder of Meze Audio
The Penta Hybrid technology allows the Meze Rai Penta to deliver a harmonised reproduction of sound frequencies, without overlay or phase problems. For the sound from the speakers to reach your eardrums, the sound wave must pass through the combination of the housing, nozzle and tips. The harmonious operation of the 5 loudspeakers is made possible by the very specific and precise length of each sound tube, which determines the volume of air present in front of each loudspeaker. This design eliminates the problems frequently found in plastic tube and shock absorber systems commonly used in IEMs with multiple speakers.
If the internal design of the Rai Penta has been designed to provide an exceptional sound reproduction, special attention has also been paid to the ergonomics of the latter. Once set up, the Rai Penta are totally forgotten to allow you to enjoy an immersive musical experience, even during long listening sessions.
The air flow control system helps to regulate the pressure in the internal chamber of the Rai Penta. To do this, Meze developed the PES system for Pressure Equalization System, placed at the front and rear of the loudspeakers to adapt the pressure.
The Aluminium frame of these IEMs benefits from precision machining using a CNC. Its shape creates the perfect space to allow sound waves to be precisely and undistorted to your ear. For greater durability, this frame is anodized. The brand logo is directly engraved in this anodized layer.
The Meze Rai Penta works well with all types of source devices due to its low impedance and high sensitivity. It is of course recommended to use a high resolution source to take full advantage of these IEMs, delivering a balanced sound and an impressive amount of detail for a flawless immersion. The assembly of the 5 loudspeakers allows the frequencies from 4Hz to 45kHz to be reproduced.
The cable supplied with the Rai Penta also benefits from excellent design quality. It incorporates Silver Copper conductors to ensure excellent signal conductivity and durable metal connectors with Rhodium plated contacts. The cable consists of 4 wires. Each yarn contains 20 strands of Litz. The cable has a 3.5mm jack connector to connect to an audio source and MMCX connectors to connect to the IEMs. The cable is therefore disconnectable and interchangeable.
Product type | In-Ear monitor (IEM) |
Drivers | Penta Hybrid 4x Customized balanced armature 1x Dynamic driver |
Frequency response | 4Hz - 45kHz |
Impedance | 20Ω |
Sensitivity | 110dB SPL/1mW |
Max input power | 30mW |
Distortion | < 1% |
Cable conductors | Silver plated Copper |
Cable connectors | MMCX to Jack 3.5mm |
Connectors plating | Rhodium |
Color | Black |
Impedance (Ω) | 20 |
Efficiency / Sensitivity (dB) | 110 |
Lowest frequency (Hz) | 4 |
Highest frequency (Hz) | 45000 |
