MOONDROP ARIA 2 In-Ear Monitors Red
New
The latest advances in Moondrop product technology are at the heart of the latest addition to the Aria series! Indeed, Moondrop's Aria 2 headphones adopt the dynamic transducer and magnetic circuit design that have made the brand so successful. However, the Aria 2 not only retains the technological basis of Moondrop's flagship products, but also combines it with a newly designed brass cavity allowing, among other things, easy replacement of the ear-tips if required, and the integration of a pressure vent to boost low frequencies.
Reference : 20984
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 12-09-2025.
Moondrop Aria 2 In-Ear Monitors IEM Dynamic 122dB 33 Ohm 16Hz-22kHz Red
MOONDROP ARIA 2 In-Ear Monitors IEM Dynamic 122dB 33 Ohm 16Hz-22kHz : Front and back view
The latest advances in Moondrop product technology are at the heart of the latest addition to the Aria series! Indeed, Moondrop's Aria 2 in-ear monitors adopt the dynamic transducer and magnetic circuit design that have made the brand so successful. However, the Aria 2 not only retains the technological basis of Moondrop's flagship products, but also combines it with a newly designed brass cavity allowing, among other things, easy replacement of the ear-tips if required, and the integration of a pressure vent to boost low frequencies.
Moondrop Aria 2: Brand-new ceramic-coated spherical dome composite diaphragm.
Aria 2 in-ear earphones feature an all-new composite membrane with titanium nitride coating.The two-step processing of three materials achieves a smooth treble response surpassing that of a metal-coated diaphragm, and ultra-low distortion performance that is lower than that of other crystalline-coated diaphragms. It delivers excellent treble detail and extension without any granularity or roughness.
Moondrop Aria 2: Replaceable acoustic nozzle.
Aria2 incorporates a new generation of replaceable acoustic filters. The front end of the brass nozzle consists of a removable tip, allowing users to replace the acoustic filter quickly and conveniently. Replacement is far easier compared with existing multi-layer filters, and the design makes for greater reliability. In the event of blockage or damage, the cost of replacement is much lower than that of standard nozzles.
MOONDROP ARIA 2 In-Ear Monitors IEM Dynamic 122dB 33 Ohm 16Hz-22kHz: Replaceable acoustic nozzle
Product typeIn-Ear Monitors IEM
Speaker driver typeDynamic
Connector2 pins 0.78mm
Impedance33 Ohm @ 1kHz
Sensitivity122dB/Vrms @ 1kHz
Frequency response16Hz - 22kHz
Total harmonic distortion (THD)≤ 0.05% @ 1kHz
CouleurRed
Package1x Moondrop Aria 2
1x Earphone Cables
12x Eartips
1x Storage Case
1x User Manual
ColorRed
Impedance (Ω)33
Efficiency / Sensitivity (dB)122.0
Lowest frequency (Hz)16
Highest frequency (Hz)22000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
MOONDROP ARIA 2 In-Ear Monitors IEM Dynamic 122dB 33 Ohm 16Hz-22kHz Red
The latest advances in Moondrop product technology are at the heart of the latest addition to the Aria series! Indeed, Moondrop's Aria 2...
