Nice, very nice
This product has been replaced by the Moondrop Aria II model.
In-Ear Monitors IEM Dynamic 10mm 122dB 32 Ohm 5Hz-36kHz
Moondrop's Aria in-ear headphones combine balance, transparency, richness and a wide sound stage. They integrate a dynamic 10mm transducer within a double magnetic cavity, with LCP (Liquid Crystal Polymer) membrane offering an excellent transient response and a detailed restitution. The ultra-thin Daikoku-CCAW coil makes the suspension system very light for a natural sound. The new waveguide significantly reduces distortion caused by high frequency phase interference. The shape of the body is designed to fit the shape of the ear perfectly, giving the Aria a clean, modern look. The body is made of precision CNC machined metal. Within it, the acoustic chamber is equipped with several tubes allowing a perfect adjustment of the frequency response. The Aria comes with a detachable cable, connecting to the headphones on a standard 2 pins 0.78mm connector.
1 | High frequency phased waveguide |
2 | Ø0.035mm CCAW voice coil |
3 | Brass inner cavity |
4 | Patented anti-clogging filter |
5 | LCP Diaphragm |
6 | N52 Neodymium magnet internal magnetic circuit |
Product type | In-ear monitors (IEM) |
Speaker driver type | 10mm Dynamic LCP |
Magnet | Neodymium N52 |
Connector | 2 pins 0.78mm |
Impedance | 32Ω ±15% @ 1kHz |
Sensitivity | 122dB/Vrms @ 1kHz) |
Frequency response | 5Hz-36kHz |
Package | Moondrop Aria Detachable cable 12x eartips Case |
Color | Black |
Impedance (Ω) | 32 |
Efficiency / Sensitivity (dB) | 122.0 |
Lowest frequency (Hz) | 5 |
Highest frequency (Hz) | 36000 |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Goran D.
Théophane B.
