MOONDROP QUARK 2 In-Ear Monitors IEM Dynamic Ø7.8mm USB-C with Microphone 20Hz-20kHz
Moondrop's latest iteration of their Quark earphones, the Quark 2, like its predecessor, aims to offer quality earphones at a contained price. To achieve this, Moondrop have used all their know-how and past experience to update one of their iconic models. The result is an earphone with a dynamic Ø7.8mm driver made from liquid crystal polymers, a redesigned cavity and an integrated DAC/AMP/DSP module capable of decoding files up to PCM 32bit 368kHz.
Reference : 19701
20,90 €tax incl.
17,42 € tax excl.
MOONDROP QUARK 2 : Front view
Moondrop Quark 2 : Composite liquid crystal polymer driver
Moondrop's Quark 2 incorporate a dynamic driver with a Liquid Crystal Polymer (LCP) diaphragm coupled to a flexible suspension for a detail-rich result with a wide frequency response. To ensure maximum efficiency and fast response, a CCAW voice coil coupled to an N52 magnetic circuit is also used, ensuring that the driver gets the best out of it.
MOONDROP QUARK 2 : composition
MOONDROP QUARK 2 : Cutaway view
Moondrop Quark 2 : A design that leaves nothing to chance
The body of the Quark 2 earphones has been given special attention to ensure the best possible fit with the driver. The design of the body has been developed to guarantee high-quality sound insulation, naturally protecting you from the outside world without the need to turn up the volume. Furthermore, the internal cavity has been designed to deliver dynamic bass, a quality that is even more impressive given the small size of the earphones. Moreover, in order to achieve a pleasant timbre, particularly when listening for long periods, a phonic filter is positioned just after the driver, attenuating the most unpleasant high frequencies while preserving all the details.
Moondrop Quark 2 : DAC, AMP and DSP
The USB-C connector on the Quark 2 earphones includes a SoC that acts as a DAC, DSP and amplifier. As a result, these earphones can be used as they are without worrying about running out of power, while offering analogue/digital conversion up to 32bit 384kHz PCM.
MOONDROP QUARK 2 :USB-C connector
MOONDROP QUARK 2 : Control module
Moondrop Quark 2 : Volume control and microphone
For furthermore practicality, the Quark 2s also feature a module for controlling the volume and playback of your tracks. This module also includes a microphone, so you can easily make phone calls while wearing your earphones.
Moondrop Quark 2 : Low latency and frequency response
In addition to the Quark 2's very low latency (<5ms), it boasts a frequency response very similar to that of the VDSF 5128 Demo model.
MOONDROP QUARK 2 : Frequency response
Product typeIn-ear monitors (IEM)
ConnectorUSB-C
Total harmonic distortion (THD)≤0.5% @1kHz
Driver typeDynamic
MembraneLiquid crystal polymers (LCP)
Voice coilCCAW
MagnetNeodymium N52
Supported sampling ratePCM up to 32bit 384kHz
ColorGrey
Package1x Moondrop Quark 2
3x Pairs of ear tips (S/M/L)
ColorGray
Impedance (Ω)NC
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationUSB-C
Headphone / Earphone connectorNon-detachable cable
Phone call featureYes
Noise reductionNo
Moondrop's latest iteration of their Quark earphones, the Quark 2, like its predecessor, aims to offer quality earphones at a contained price....
