MOONDROP RAYS In-Ear Monitors
With the Rays, Moondrop is presenting in-ear monitors with USB-C termination. These are based on a pair of drivers combining dynamic and planar magnetic technology to effectively cover the entire frequency band. The cable supplied incorporates a DSP allowing you to create your own custom equalisation, while an NPU chip and a specially-trained algorithm provide significant noise reduction while preserving human voices.
Reference : 20793
99,00 €tax incl.
82,50 € tax excl.
Moondrop Rays In-Ear Monitors IEM Dynamic Planar Magnetic 30 Ohm 120dB 7Hz-39kHz
Moondrop Rays : Front view
Moondrop Rays: Dual speakers
The Rays earphones use a hybrid two-driver configuration, combining a dynamic driver and a planar driver. This configuration covers an ultra-wide frequency range with very low distortion, improving the precision of the transient response and enabling finer spatial positioning.
Moondrop Rays : Speaker composition
Moondrop Rays: USB-C termination with built-in DSP
The Rays come with a USB-C terminated cable so you can connect directly to all your equipment without the need for an external DAC. The USB connector also incorporates a DSP that rivals the quality of many audio interfaces, offering excellent resolution, a clear soundstage and impressive dynamics.
Moondrop Rays :USB-C termination with DSP
Moondrop Rays : EQ
Moondrop Rays: Customisable EQ
Thanks to the inclusion of DSP, Rays reproduction is highly customisable. You can create a fully customised equaliser via the Moondrop app available on Android and iOS or their website, and load it into your earphones, so you can always enjoy it without needing to use external services.
Moondrop Rays: AI noise reduction
The audio chip used also incorporates a NPU (Neural Processing Unit) and combines it with an advanced ambient noise cancellation algorithm trained to recognise the human voice. As a result, these earphones offer impressive noise reduction while retaining voices perfectly, allowing you to make calls or play in noisy environments without worry.
Moondrop Rays : noise reduction
Moondrop Rays: 3D printing
In response to the demands of acoustic design, Moondrop uses a high-precision 3D printing process to achieve exceptionally fine control over the final shape of the cavity, guaranteeing a flawless listening experience combined with excellent wearing comfort.
Moondrop Rays : 3D printing
Moondrop Rays : Natural frequency response
The Rays were designed to be as close as possible to the VDSF curve, offering a natural sound reproduction.
Frequency response curve
Product typeIn-ear monitors
Drivers1x Dynamic driver Ø10mm
1x Planar magnetic driver Ø6mm
Impedance18.5Ω ±15% @ 1kHz
Sensitivity120dB @ 1kHz
Frequency response7Hz-39kHz
Total harmonic distortion more noise (THD+N)≤ 0.05% @ 1kHz
Earphone connectors0.78mm 2pin
Cable terminationUSB-C
MicrophoneYes
ColorGreen
Purple
Package1x Moondrop Rays
USB-C cable
1x Storage case
3x Pairs of ear tips (S/M/L)
ColorGreen
ColorViolet
Impedance (Ω)30
Efficiency / Sensitivity (dB)120.0
WirelessNo
Phone call featureYes
Noise reductionYes
MOONDROP RAYS In-Ear Monitors IEM Dynamic Planar Magnetic 30 Ohm 120dB 7Hz-39kHz
With the Rays, Moondrop is presenting in-ear monitors with USB-C termination. These are based on a pair of drivers combining dynamic and planar...
