The Noble FoKus Rex5 are premium wireless earphones combining a total of five drivers with dynamic, planar magnetic and balanced armature technologies for detailed, balanced and extended sound. Equipped with a Qualcomm QCC3091 chip and Bluetooth 5.4, they support hi-res codecs, including LDAC and aptX Adaptive. Audiodo calibration personalises the sound, while ANC, transparency mode and extended battery life ensure versatile listening for everyday use.
The Noble FoKus Rex5 features a hybrid configuration with five transducers: a 10 mm dynamic driver, a 6 mm planar magnetic driver and three balanced armature drivers. This combination delivers extended reproduction across the entire spectrum, with deep bass, precise midrange and clear, non-aggressive treble. The sound can be fine-tuned using the Audiodo Personal Sound software, included in the Noble FoKus app available on Android and iOS, which measures the user's hearing and applies a personalised equalisation setting stored directly in the earphones.
The FoKus Rex5 headphones are powered by a Qualcomm QCC3091 chip, which is Bluetooth 5.4 compatible and supports SBC, AAC, aptX Adaptive and LDAC codecs for high-resolution audio transmission. They feature effective active noise cancellation (ANC) and a transparency mode to adjust isolation according to the environment. The multipoint function allows multiple devices to be connected simultaneously, and the charging case, which is compatible with wired and wireless charging, provides up to 32 hours of total battery life.
| Specifications | |
| Product type | True Wireless In-Ear Monitor (IEM) |
| Drivers | 1x Dynamic 3x Balanced armature 1x Planar magnetic |
| Bluetooth chip | QCC3091 |
| Bluetooth version | 5.4 |
| Supported codecs | SBC AAC aptX Adaptive LDAC |
| Earphone autonomy | 5-7h |
| Case autonomy | 18-25h |
| Frequency response | 20Hz-40kHz |
| General | |
| Color | Black |
| Package | 1x Noble FoKus Rex5 1x Charging case 9x Pairs of ear tips (S, M and L) 1x USB Type-C cable |
| Color | Black |
| Impedance (Ω) | NC |
| Efficiency / Sensitivity (dB) | N/A |
| Wireless | Yes |
| Cable termination | NC |
| Headphone / Earphone connector | NC |
| Phone call feature | Yes |
| Noise reduction | Yes |
