SIMGOT ET142 In-Ear Monitors
The SIMGOT ET142 are Hi-Fi hybrid in-ear monitors combining a 12.5mm planar magnetic driver with a multilayer ceramic piezoelectric driver to deliver detailed, fast and extended sound reproduction across the entire frequency range.
Reference : 22209
249,00 €tax incl.
207,50 € tax excl.
Simgot ET142 Pn-Ear Monitors IEM Planar Magnetic 14 Ohm 118dB 8Hz–40kHz
SIMGOT ET142
The Simgot ET142 are Hi-Fi hybrid in-ear monitors combining a 12.5mm planar magnetic driver with a multilayer ceramic piezoelectric driver to deliver detailed, fast and extended sound reproduction across the entire frequency range. Featuring an impedance of 14Ω ±15%, a sensitivity of 118dB/Vrms (@1kHz) and a frequency response extending from 8Hz to 40kHz, they are easy to drive with digital audio players, DAC/headphone amplifiers and smartphones. They come supplied with a premium detachable 732-strand Litz cable made from OFC copper and silver-plated OFC copper, equipped with 0.78mm 2-pin CIEM connectors and an interchangeable plug system featuring both 3.5mm single-ended and 4.4mm balanced terminations, ensuring broad compatibility with most audio sources.
Simgot ET142: High-Precision Planar Magnetic Driver
The ET142 features a large 12.5mm planar magnetic driver, renowned for its lightweight and precisely controlled diaphragm. This technology delivers outstanding transient response, low distortion and exceptionally accurate micro-detail reproduction, with controlled bass, natural mids and extended highs.
SIMGOT ET142: High-Precision Planar Magnetic Driver
SIMGOT ET142: Hybrid Architecture with Piezoelectric Driver
Simgot ET142: Hybrid Architecture with Piezoelectric Driver
To further enhance high-frequency reproduction, the planar driver is paired with a multilayer ceramic piezoelectric driver. This hybrid configuration extends the frequency response up to 40kHz while adding greater airiness, finesse and detail to the treble without compromising the overall tonal balance.
Simgot ET142: Premium Cable with Interchangeable Terminations
The Simgot ET142 comes with a 732-strand audiophile-grade Litz cable made from OFC copper and silver-plated OFC copper to ensure excellent conductivity and optimal signal transmission. Thanks to its detachable 0.78mm 2-pin connectors and interchangeable 3.5mm and 4.4mm plugs, it easily adapts to both single-ended and balanced audio sources.
SIMGOT ET142: Premium Cable with Interchangeable Terminations
Technical Specifications
Product typeIn-ear monitors (IEMs)
Drivers12.5mm planar magnetic + multilayer ceramic piezoelectric
Impedance14Ω ±15% (@1kHz)
Sensitivity118dB/Vrms (@1kHz)
Frequency response8Hz–40kHz
Detachable cable
Cable structure732-strand mixed OFC copper and silver-plated Litz cable
Earphone connectors0.78mm CIEM
Cable terminationInterchangeable 3.5mm single-ended or 4.4mm balanced plug
Package contents1x Simgot ET142 IEM
ColorSilver
Impedance (Ω)14
Efficiency / Sensitivity (dB)118.0
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
SIMGOT ET142 In-Ear Monitors IEM Planar Magnetic 14 Ohm 118dB 8Hz–40kHz
The SIMGOT ET142 are Hi-Fi hybrid in-ear monitors combining a 12.5mm planar magnetic driver with a multilayer ceramic piezoelectric driver to...
