SIMGOT EW300 DSP In-Ear Monitors
The SIMGOT EW300 DSP are tribrid in-ear monitors designed to deliver detailed and balanced sound reproduction through an architecture combining a 10mm dynamic driver with a ceramic composite diaphragm and dual acoustic chamber, a 6mm annular planar driver, and a ceramic piezoelectric (PZT) driver dedicated to high frequencies.
Reference : 22208
96,90 €tax incl.
80,75 € tax excl.
Simgot EW300 DSP Tribrid In-Ear Monitors IEM 1DD + 1Planar + 1PZT 28 Ohm 121dB 20Hz-20kHz USB-C
SIMGOT EW300 DSP
The Simgot EW300 DSP are tribrid in-ear monitors designed to deliver detailed and balanced sound reproduction through an architecture combining a 10mm dynamic driver with a ceramic composite diaphragm and dual acoustic chamber, a 6mm annular planar driver, and a ceramic piezoelectric (PZT) driver dedicated to high frequencies. This combination provides deep bass, accurate mids, and treble rich in micro-detail. The EW300 feature a 28Ω impedance (±15% at 1kHz) and a sensitivity of 121dB/Vrms at 1kHz (using the silver-plated steel nozzle with the red silicone ring), ensuring easy drivability with most digital audio players, portable DAC/headphone amplifiers, and compatible smartphones. Their frequency response extends from 8Hz to 40kHz, with an effective frequency range of 20Hz to 20kHz. They use detachable 0.78mm 2-pin connectors paired with a high-purity silver-plated OFC copper cable terminated with a USB-C connector integrating a DSP processor and a microphone. Included accessories comprise two sets of interchangeable acoustic nozzles, three pairs of silicone ear tips (S/M/L), four acoustic tuning foams, six silicone rings, a carrying case, and a user manual.
Simgot EW300 STD: Tribrid Architecture with 1DD + 1 Planar + 1 PZT
The EW300 combines three driver technologies to take advantage of the strengths of each. The 10mm dynamic driver with its ceramic composite diaphragm and dual acoustic chamber delivers deep, tightly controlled bass. The 6mm annular planar driver provides speed, precision, and richness throughout the midrange, while the ceramic piezoelectric (PZT) driver extends the high-frequency response, enhancing detail retrieval and a sense of airiness.
SIMGOT EW300 STD: Tribrid Architecture with 1DD + 1 Planar + 1 PZT
SIMGOT EW300 STD: Interchangeable Acoustic Nozzles and Dual Sound Signatures
Simgot EW300 STD: Interchangeable Acoustic Nozzles and Dual Sound Signatures
The Simgot EW300 features a system of interchangeable acoustic nozzles that allows users to choose between two distinct sound signatures. Each set of nozzles is based on a dedicated acoustic tuning inspired by the Simgot-Golden2023 and H-2019 target curves, offering either a more balanced and natural presentation or a more open sound with enhanced treble airiness. The threaded mounting system enables quick nozzle replacement, allowing the sound to be tailored to different music genres or personal preferences while maintaining high-resolution playback and excellent tonal balance across the entire frequency spectrum.
Simgot EW300 STD: USB-C Cable with Integrated DSP and Microphone
This DSP version comes equipped with a detachable high-purity silver-plated OFC copper cable terminated with a USB-C connector integrating both a DSP processor and a microphone. This configuration enables direct connection to smartphones, tablets, and computers equipped with a USB-C port while benefiting from optimized digital signal processing. The 0.78mm 2-pin connectors also make cable replacement quick and easy, providing excellent modularity and broad compatibility with a wide range of aftermarket cables.
SIMGOT EW300 STD: Detachable Cable and Comprehensive Accessories
Technical Specifications
Product TypeIn-Ear Monitors (IEMs)
ConfigurationTribrid
1x Dynamic Driver + 1x Planar Magnetic Driver + 1x Ceramic Piezoelectric Driver
Dynamic Driver10mm Dual-Chamber Dynamic Driver with Ceramic Composite Diaphragm
Planar Magnetic Driver6mm Annular Planar Magnetic Driver
Sensitivity121dB/Vrms (at 1kHz, silver-plated steel nozzle with red silicone ring)
119dB/Vrms (at 1kHz, gold-plated copper nozzle with purple silicone ring)
Frequency Response8Hz–40kHz
Effective Frequency Response20Hz–20kHz
Detachable Cable
Earphone Connector0.78mm CIEM
Cable ConductorHigh-Purity Silver-Plated OFC Copper
Cable TerminationUSB-C
Microphone
Package Contents1x Simgot EW300 DSP
2x Nozzles
3x Eartips(S/M/L)
4x Tuning Foam
6x Silicone Ring
1x Simgot Earbuds Case
ColorSilver
Impedance (Ω)28
Efficiency / Sensitivity (dB)121.0
WirelessNo
Cable terminationUSB-C
Phone call featureYes
Noise reductionNo
SIMGOT EW300 DSP Tribrid In-Ear Monitors IEM 1DD + 1Planar + 1PZT 28 Ohm 121dB 20Hz-20kHz USB-C
The SIMGOT EW300 DSP are tribrid in-ear monitors designed to deliver detailed and balanced sound reproduction through an architecture...
