SIMGOT EW300 STD In-Ear Monitors
The SIMGOT EW300 STD are tribrid in-ear monitors designed to deliver detailed and balanced sound reproduction through an architecture combining a 10mm dynamic driver with a ceramic composite diaphragm and dual acoustic chamber, a 6mm annular planar driver, and a ceramic piezoelectric (PZT) driver dedicated to high frequencies.
Reference : 22206
84,57 €tax incl.
70,47 € tax excl.
Shipping date: 17-11-2026.
Simgot EW300 STD Tribrid In-Ear Monitors 1DD + 1Planar + 1PZT 28 Ohm 121dB 20Hz-20kHz
SIMGOT EW300 STD
The Simgot EW300 STD are tribrid in-ear monitors designed to deliver detailed and balanced sound reproduction through an architecture combining a 10mm dynamic driver with a ceramic composite diaphragm and dual acoustic chamber, a 6mm annular planar driver, and a ceramic piezoelectric (PZT) driver dedicated to high frequencies. This combination provides deep bass, accurate mids, and treble rich in micro-detail. The EW300 feature a 28Ω impedance (±15% at 1kHz) and a sensitivity of 121dB/Vrms at 1kHz (using the silver-plated steel nozzle with the red silicone ring), ensuring easy drivability with most digital audio players, portable DAC/headphone amplifiers, and compatible smartphones. Their frequency response extends from 8Hz to 40kHz, with an effective frequency range of 20Hz to 20kHz. They use detachable 0.78mm 2-pin connectors paired with a high-purity silver-plated OFC copper cable terminated with a 3.5mm stereo jack (STD version). Included accessories comprise two sets of acoustic nozzles, three pairs of silicone ear tips (S/M/L), four acoustic tuning foams, six silicone rings, a carrying case, and a user manual.
Simgot EW300 STD: Tribrid Architecture with 1DD + 1 Planar + 1 PZT
The EW300 combines three driver technologies to take advantage of the strengths of each. The 10mm dynamic driver with its ceramic composite diaphragm and dual acoustic chamber delivers deep, tightly controlled bass. The 6mm annular planar driver provides speed, precision, and richness throughout the midrange, while the ceramic piezoelectric (PZT) driver extends the high-frequency response, enhancing detail retrieval and a sense of airiness.
SIMGOT EW300 STD: Tribrid Architecture with 1DD + 1 Planar + 1 PZT
SIMGOT EW300 STD: Interchangeable Acoustic Nozzles and Dual Sound Signatures
Simgot EW300 STD: Interchangeable Acoustic Nozzles and Dual Sound Signatures
The Simgot EW300 features a system of interchangeable acoustic nozzles that allows users to choose between two distinct sound signatures. Each set of nozzles is based on a dedicated acoustic tuning inspired by the Simgot-Golden2023 and H-2019 target curves, offering either a more balanced and natural presentation or a more open sound with enhanced treble airiness. The threaded mounting system enables quick nozzle replacement, allowing the sound to be tailored to different music genres or personal preferences while maintaining high-resolution playback and excellent tonal balance across the entire frequency spectrum.
Simgot EW300 STD: Detachable Cable and Comprehensive Accessories
The Simgot EW300 uses detachable 0.78mm 2-pin connectors, making cable replacement or upgrades easy. The STD version comes equipped with a high-purity silver-plated OFC copper cable terminated with a 3.5mm stereo jack and does not include a microphone, ensuring excellent signal transmission quality. The earphones are supplied with a carrying case, three sizes of silicone ear tips, interchangeable acoustic nozzles, acoustic tuning foams, and silicone rings for enhanced comfort and sound customization.
SIMGOT EW300 STD: Detachable Cable and Comprehensive Accessories
Technical Specifications
Product TypeIn-ear monitors (IEMs)
ConfigurationTribrid
1x Dynamic driver + 1x Planar magnetic driver + 1x Ceramic piezoelectric driver
Dynamic Driver10mm Dual-Chamber Dynamic Driver with Ceramic Composite Diaphragm
Planar Magnetic Driver6mm Annular Planar Magnetic Driver
Sensitivity121dB/Vrms (at 1kHz, silver-plated steel nozzle with red silicone ring)
119dB/Vrms (at 1kHz, gold-plated copper nozzle with purple silicone ring)
Frequency Response8Hz–40kHz
Effective Frequency Response20Hz–20kHz
Detachable Cable
Earphone Connector0.78mm CIEM
Cable ConductorHigh-Purity Silver-Plated OFC Copper
Cable Termination3.5mm Jack
Microphone
Package Contents1x Simgot EW300 STD
2x Nozzles
3x Eartips(S/M/L)
4x Tuning Foam
6x Silicone Ring
1x Simgot Earbuds Case
ColorSilver
Impedance (Ω)28
Efficiency / Sensitivity (dB)121.0
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
SIMGOT EW300 STD Tribrid In-Ear Monitors IEM 1DD + 1Planar + 1PZT 28 Ohm 121dB 20Hz-20kHz
The SIMGOT EW300 STD are tribrid in-ear monitors designed to deliver detailed and balanced sound reproduction through an architecture combining a...
