THIEAUDIO ORIGIN In-Ears Monitors
Thieaudio Origin in-ear monitors are high-end earphones featuring a Quabrid 1DD + 4BA + 2EST + 1BC design per monitor, for a total of 16 drivers. Thieaudio, in addition to its meticulous design, gives the IEM Origin the benefit of its fine expertise, with settings for an immersive audio experience.
By buying this product you get 95 loyalty points
Reference : 19890
959,00 €tax incl.
799,17 € tax excl.
Thieaudio Origin In-Ears Monitors IEM Quadbrid 9Ω 102dB 20Hz-44kHz
Thieaudio Origin picture
Thieaudio Origin in-ear monitors are high-end earphones featuring a Quabrid 1DD + 4BA + 2EST + 1BC design per monitor, for a total of 16 drivers. Thieaudio, in addition to its meticulous design, gives the IEM Origin the benefit of its fine expertise, with settings for an immersive audio experience. The IEM Origin are specially designed for bass lovers, yet remain balanced across their entire sound spectrum, with accurate midrange and natural extended highs. Their 9 ohm impedance and 102dB sensitivity make them easy to drive. In addition, the electrostatic drivers deliver rich highs with an extended frequency response of 20Hz-44kHz. A detachable 0.78mm CIEM audiophile cable with interchangeable 3.5mm jack, 2.5mm jack and balanced 4.4mm jack terminations completes the package.
Thieaudio Origin: hybrid design with 4 driver types per earphone
The Thieaudio Origin features a set of 4 driver types per earphone, promising textured sound reproduction. Indeed, two electrostatic drivers act as super-tweeter, two Knowles TWFk-30017 take care of the treble, two full-range Sonion 2600 take care of the midrange, while a Ø10mm bio-cellulose dynamic driver offers immersive bass. The internal 11mm Bone Driver (BC) adds texture to the midrange and treble.
La conception des Thieaudio Origin
Thieaudio Origin: deep bass and refined tuning
Specially designed for bass enthusiasts, Thieaudio Origin features the most committed bass signature in the Thieaudio catalog. With 12dB of sub-bass precisely cut at 250kHz. However, despite this emphasis on bass, the final result remains balanced thanks to Thieaudio's fine-tuning. This configuration offers what many users are looking for: very present bass and highly detailed mids and highs for a perfect tonal signature.
Photo des Thieaudio Origin
Thieaudio Origin: focus on the BC driver
Tuned to target the midrange and treble, the BC driver greatly enhances the listening experience with Thieaudio Origin. Thanks to its tactile vibrations, it adds a new dimension to sound rendering, resulting in a wider soundstage.
Thieaudio Origin: an audiophile cable
A detachable 0.78mm to interchangeable termination cable allows the user to choose between 3.5mm jack, 2.5mm jack or balanced 4.4mm jack terminations for use with a wide range of devices. This cable features high-quality components, including a silver-plated LCOFC 5N 7x7x0.08mm wire and a silver-plated LCOFC 4N 16x7x0.06mm wire. With a cross-section of 20AWG, it ensures optimum signal transmission. In addition, the cable incorporates spiral shielding and Litz Type 2 technology for greater durability and reduced signal loss.
Photo des Thieaudio Origin et de leur câble
Product typeIn-ear monitors
Drivers1x Dynamic driver
2x Electrostatic Sonion
2x Knowles TWFk-30017
2x Sonion 2600
1x BC (Bone conductor)
Frequency response20Hz-44kHz
Sensibility102dB (±1dB) @ 1kHz
Impedance9Ω @ 1kHz
Cable typeDetachable
Earphone connectorsCIEM 0.78mm
Cable terminaisonInterchangeable
Package1x Thieaudio Origin Quadbrid earphones pair
1x Elitenoir V2 0.78mm CIEM cable to interchangeable termination
1x Jack 3.5mm termination
1x Termination Jack 4.4mm balanced
ColorBlue
Impedance (Ω)9
Efficiency / Sensitivity (dB)102.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 2.5mm
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
THIEAUDIO ORIGIN In-Ears Monitors IEM Quadbrid 9 Ohm 102dB 20Hz-44kHz
Thieaudio Origin in-ear monitors are high-end earphones featuring a Quabrid 1DD + 4BA + 2EST + 1BC design per monitor, for a total of 16 drivers....
