TRUTHEAR HEXA In-Ear Monitor
Truthear's Hexa are high-performance in-ear earphones combining a dynamic driver and three balanced armature drivers with a hybrid structure for very natural bass and midrange sound reproduction, and treble reproduction that varies greatly according to the type of eartip used: clear and natural when used with silicone eartips, and softer and more delicate when used with foam eartips.
Reference : 20427
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 02-05-2025.
Truthear Hexa In-Ear Monitor IEM Dynamic Balanced Armature 20.5Ω 120dB 8Hz-40kHz
Truthear Hexa : Front view
Truthear's Hexa
are high-performance in-ear monitor combining a dynamic driver and three balanced armature drivers with a hybrid structure for very natural bass and midrange sound reproduction, and treble reproduction that varies greatly according to the type of eartip used: clear and natural when used with silicone eartips, and softer and more delicate when used with foam eartips.
Truthear Hexa: A combo of 4 drivers
Hexa uses four drivers to effectively cover the entire frequency range. Low frequencies are handled by a Ø10mm dynamic driver with a liquid crystal polymer (LCP) diaphragm and polyurethane suspension. The weighted voice coil used has been specially selected to reduce the driver's resonant frequency and increase its impedance, delivering furthermore punchy bass and meeting the need for precise frequency range distribution.
A pair of composite balanced armature drivers are responsible for the midrange, which has been specially tuned to precisely complement the dynamic driver while rigorously conforming to HRTF characteristics.
Finally, a custom balanced armature tweeter, with characteristics very similar to Knowles' WBFK series, is responsible for high frequencies, not only effectively complementing the frequency band coverage, but also offering a fine, precise rendering of high frequencies.
Truthear Hexa : earphones set on stone
Truthear Hexa : connector overview
Truthear Hexa: Highly refined design
The Hexa's internal cavity has been machined using DLP (Digital Light Processing) 3D printing, a process that enables an otherwise impossible level of design finesse to be achieved. As a result, Truthear was able to design a waveguide structure adapted to each driver, merging their renderings into a coherent whole as close as possible to what the brand wished for in terms of sound reproduction.
Truthear Hexa: Sound profile
All this engineering gives Hexa a sound reproduction with powerful bass without being intrusive, natural midrange and bass, with no clear cross-hatching between the different drivers, and treble whose reproduction is greatly modified according to the type of tip used: clear and natural when used with silicone tips, and softer and more delicate when used with foam tips.
Truthear Hexa: Silver-plated cable
The Hexa comes with a 1.20m silver-plated copper 3.5mm to 0.78mm 2-pin jack cable, guaranteeing high-quality signal transmission without external interference.
Product typeIn-ear monitors (IEM)
Speakers type1x Dynamic driver
3x Balanced armature drivers
Dynamic driver diaphragmØ10mm in liquid crystal polymer (LCP)
Impedance20.5Ω ±15% @ 1kHz
Sensitivity120dB @ 1kHz
Total harmonic distortion (THD)≤ 1% @ 1kHz (94dB)
Frequency response5Hz-40kHz
CableDetachable
Cable length1.2m
Earphone connectors0.78mm 2 pins
Cable terminationJack 3.5mm
Cable materialsSilver-plated copper
Package1x Truthear Hexa
1x 3.5mm jack to 0.78mm 2-pin cable
1x Carrying bag
7x Pairs of ear tips
Impedance (Ω)20
Efficiency / Sensitivity (dB)120.0
Lowest frequency (Hz)8
Highest frequency (Hz)40000
WirelessNo
Phone call featureNo
Noise reductionNo
TRUTHEAR HEXA In-Ear Monitor IEM Dynamic Balanced Armature 20.5 Ohm 120dB 8Hz-40kHz
Truthear's Hexa are high-performance in-ear earphones combining a dynamic driver and three balanced armature drivers with a hybrid structure...
