AIYIMA A07 Class D Amplifier TPA3255 2x225W 4 Ohm
The Aiyima A07 is a small, simple, powerful, efficient and affordable Class D amplifier, ideal for setting up an audio system that requires a lot of power input. It embeds a TPA3255 amplifier chip capable of developing a large power of 2x225W under 4Ω, with high efficiency. The input are in stereo RCA or on Jack 3.5mm.
Reference : 15661
69,90 €tax incl.
58,25 € tax excl.
Aiyima A07
Class D Amplifier TPA3221 Bluetooth 5.0 aptX HD 2x225W 4 Ohm
Aiyima A07 Amplificateur Class D TPA3255 2x260W 4
The Aiyima A07 is a small, simple, powerful, efficient and affordable Class D amplifier, ideal for setting up an audio system that requires a lot of power input. It embeds a TPA3255 amplifier chip capable of developing a large power of 2x225W under 4Ω, with high efficiency. The input are in stereo RCA or on Jack 3.5mm. In addition, it is equipped with two upgraded LM4562 OPAs with excellent performance.
Test of AIYIMA A07 by Audio Science Review
" These TPA3255 based amps seem to have good bones in them, producing above average performance for peanuts. I am going to recommend the AIYIMA A07 based on its performance."
Test du Loxjie A30 par Audio Science Review
Product typeAmplifier
Amplifier typeClass D
Amplification chipTPA3255
OPA2x LM4562
Input1x Stereo RCA
OutputSpeaker terminals
SNR110dB
Frequency response20Hz - 20kHz (±3dB)
THD0.008%
Speakers impedance4-8Ω
Output power2x225W @ 4Ω, 48V
Supply voltage32 - 48VDC (power supply sold separately)
Dimensions100 x 151 x 33mm
Package1x Aiyima A07
InputJack 3.5mm
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)225.0
3 reviews
Surpisingly good!!
I was looking to buy something cheap to replace my meridian 556 amp until it's fixed. I have the B&W 685 speakers (first edition) and this amp sounds so clear and detailed. I think it lucks some power compared to the meridian even with the "Switched Mode Power Supply 100-240V AC to 48V 7A DC". It is loud but I think it cannot drive the speakers with power compared to a transistor amp. But it is loud and clear, so I give it 5 stars for the money!
The service and experience from audiophonics is one of the best I had, very fast shipping and very good packaging! Thank you!!
This review has been posted for AIYIMA A07 Class D Amplifier TPA3255 2x225W 4 Ohm
A no-brainer
This is a no-brainer. I prefer it to an Ncore I had. But it's of course dependent on your other equipment, your needs in terms of sound pressure and of course your tastes. Highly recommended.
Répond à mes besoins
En remplacement d'un fxaudio indisponible, recommandé par audiophonics.
Il me sert de blocs de puissance pour alimenter des enceintes atmos.
Fait très bien le job et amplement suffisant.
Et pourtant à la base je ne suis pas du tout un aficionados de la classe D.
Je recommande pour dette utilisation.
 (3)
The Aiyima A07 is a small, simple, powerful, efficient and affordable Class D amplifier, ideal for setting up an audio system that requires a lot...
