AUDIO-GD MASTER 10 2019 EDITION Class-A Balanced Amplifier ACSS 2x 500W 4 Ohm
The Audio-GD Master 10 is an impressive Symmetrical Amplifier in Class A, capable of delivering great power to accompany the most demanding speakers.
By buying this product you get 229 loyalty points
Reference : 9502
2 290,00 €tax incl.
1 908,34 € tax excl.
This model has been replaced by the Master 10 MK2 version.
Integrated Amplifier / Class A Symmetrical ACSS
Audio-GD MASTER-10
Édition 2019
Linear Fidelity & Non Negative Feedback
Pour cette Édition 2019 de son Master 10, Audio-GD à mis à jour son amplificateur Class A pour lui permettre d'offrir des mesures audio toujours meilleures. La marque intègre ainsi les technologies Linear Fidelity aux circuits de sorties et Non Negative Feedback à l'amplificateur de manière générale. Ce design particulier permet d'obtenir une courbe de réponse linéaire ainsi qu'un niveau de distorsion très faible, pour une restitution sonore d'une très grande transparence et ce quelle que soit le niveau de sortie et la fréquence reproduite.
An integrated amplifier of high power ...
Audio-GD introduces us once again to the quintessence of the audio technology with this Master 10 amplifier with more than neat and clean architecture.
The famous brand of high-fidelity audio offers here an amplifier in the most accomplished form possible with outstanding performance: it delivers 2x 250W under 8 Ohm, and 2x 500W under 4 Ohm.
Every product of the brand is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzer 2700 Series from Audio Precision.
Extremely efficient clean connections
The Master 10 has 5 analog inputs: 2x RCA / 2x XLR / 1x ACSS. The output is of course on 2 HP terminals, where you just have to connect your speakers to enjoy.
The result is unmatched: great musicality, thanks to an exceptional dynamic and a rich sound extremely detailed in all points. You can tell you that you are approaching - see attPerfect with this HiFi device.
Arrière Audio-GD MASTER-10
An unusual amplifier
Class A Symmetric / R-Core / ACSS / Integrated
This Master 10 is equipped with no less than 4 transformers including 2 R-Core for a total of 1500W, 140,000uF of very high-end Nover capacitors, and 24 very high performance MJL1302 / 3281 transistors for the output stage .
This amplifier is also designed around a purely symmetrical discrete circuit of Class A ACSS, with separate power supply to avoid any interference or electromagnetic disturbances on the signal.
Audio-GD MASTER-1
ACSS
ACSS
Audio-GD has its own technology signature called ACSS for "Audio-GD Current System Signal". Thanks to the firm's expertise and know-how, this technology offers a less colorful, detailed soundt unparalleled neutrality.
Every professional engineer of the brand is, in addition to being experienced, a passionate of HiFi and Audio like you and us. That is, when the ACSS output is used, the XLR and RCA outputs go to MUTE.
Class A
A class A amplifier has the particularity of having all its active components always in conduction. They fully amplify the input signal, thereby limiting harmonic distortion on the output signal. The outgoing signal of the Master 10 is therefore of excellent quality, due to the absence of this famous distortion of crossing of the alternations of the sinusoids.
Class A
SNR> 115dB
Output voltage58V
Input sensitivity0.775Vrms (RCA) / 1.55Vrms (XLR) / 2mA rms (ACSS)
Frequency response20Hz - 20kHz (0.01dB)
Outputs2x Borniers HP Stéréo
Inputs2x RCA
2x XLR
1x ACSS
Input impedance47KΩ (RCA) / 94KΩ (XLR) / < 10Ω (ACSS)
Diaphony> -120dB
Ouput power2x250W under 8Ω / 2x500W under 4Ω
Switch Class A / Class ABClass A up to 10W at 8 Ohm / Class AB from 10 to 250W at 8 Ohm
Divers
Consumption130W
Power supply4 Transformers including 2 R-Core for 1600W
WeightAround 40kg
Housing material100% Aluminium
Dimensions480 x 440 x 190mm
AccessoriesPower supply cable
Metal remote control
InputXLR
InputACSS
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)250.0
6 reviews
100% worth the money you pay
Was thinking about Master 10 for many years and since I have bought it I never had any regrets. It's working together with DALI Helicon 800 and it's capable to control them without any issues.
Very sophisticated and neutral sound with full control of the bass!
Aleksandr
This review has been posted for AUDIO-GD MASTER 10 2019 EDITION Class-A Balanced Amplifier ACSS 2x 500W 4 Ohm
RQP époustouflant
C'est sûr, le RQP de ce produit est impressionant. Histoire d'aider les autres audiophiles dans leur choix, je vais tenter d'apporter quelques infos supplémentaires.
J'ai acheté cet ampli pour remplacer un Audio Analogue Grand Maestro que je n'étais pas sûr de pouvoir faire réparer. Le Grand Maestro est sorti en 2001 à environ 4000 €, ce qui ferait 5300 euros d'aujourd'hui.
Résultat ? l'AA étant un classe A, il ne manque pas de dynamique, mais le M10 en a encore un peu plus, et surtout une meilleure présence et fermeté dans les graves. Par contre, en terme de finesse, fluidité, raffinement des timbres, domaines de prédilection de la marque AA, le M10 est plutôt en retrait, même s'il s'en tire remarquablement bien pour son prix.
En conclusion, j'aurais envie de dire que les deux amplis sont comparables, chacun avec ses avantages.
Quoiqu'il en soit, si vous avez 2200 € à mettre dans un ampli, c'est vraiment ce M10 qu'il faut acheter.
Excellent RQP, mais quand même ...
Aucun doute, pour le même prix, les amplis des autres marques font pâle figure à côté du M10. Mais quand même il ne faut pas exagérer.
J'ai acheté cet ampli pour remplacer un vieil Audio Analogue Grand Intégré. C'est un ampli double mono de 52 kg, qui se vendait dans les 4000 € dans les années 2000 (équivalent à 5000-5500 € d'aujourd'hui). En comparant les 2 amplis, je dirai que le M10 est un peu meilleur en fermeté du grave et en dynamique, mais que le AA est plus naturelle, et surtout respecte mieux les timbres des instruments. Le M10 parait parfois un peu crispé sur des violons ou des cuivres. Ma femme m'a dit que le nouvel ampli est pas mal, mais que le vieux avant plus de corps.
Master 10
Bonjour,
Comme à chaque fois livraison rapide et sérieuse merci AUDIOPHONICS.
A bientôt 60 ans et passionné de hifi depuis l'âge de 14 ans des appareils pas besoin de vous dire que il y en a eu beaucoup...
Que dire du Master 10 reçu avant hier et mis en service hier.
Cet appareil en impose par ses dimensions et son poids , mais le résultat sonore est tout à fait Exceptionnel...Un ampli de haut de gamme au RQP imbattable , il est détaillé, équilibré, pas d'agressivité ,tenue du grave, image sonore en 3 D, puissant ...Bref un ampli complet qui fait de la très bonne musique. Perso je ne regrette pas mon achat devant tant de qualités...Il faudrait mettre au moins 3 fois le prix pour le même rendu chez d'autres concurrents.... Le Master est tout simplement un ampli de haute volée à consommer sans modération...
Stéphane.
Il m'a rénové ma HIFI
Ampli de très bonne qualité,et très puissant ! excellent rapport qualité prix pour le moment je n'ai pas eu de problèmes depuis environ 6 mois, en plus une télécommande en alu très résistante..
