CLOUDYX CL-250W A98 Amplifier WiFi DLNA AirPlay2 Bluetooth Phono 5.0 2x100W 4 Ohm
The CloudyX CL-250W A98 is a versatile and powerful amplifier, extremely practical, especially because of its complete wireless reception. It supports WiFi 2.4G (DLNA and AirPlay2) and Bluetooth 5.0 to simply stream music remotely from a computer, NAS or smartphone.
Reference : 14987
249,00 €tax incl.
207,50 € tax excl.
CloudyX CL-250W A98
Amplifier WiFi DLNA AirPlay2 Bluetooth 5.0 HDMI 2x100W 4 OhmCloudyX CL-250W A98 Amplificateur WiFi DLNA AirPlay2 Bluetooth 5.0 HDMI 2x100W 4 Ohm
The CloudyX CL-250W A98 is a versatile and powerful amplifier, extremely practical, especially because of its complete wireless reception. It supports WiFi 2.4G (DLNA and AirPlay2) and Bluetooth 5.0 to simply stream music remotely from a computer, NAS or smartphone. The amplifier stage is capable of delivering 2x100W of power at 4Ω. The CL-250W A98 also offers a MM phono input for a vinyl turntable.
Control app
The CL-250W A98 can be controlled via the Muzo mobile application. This application makes it easy to manage broadcasting and playback through an ergonomic and intuitive interface.
The application is also compatible with many popular streaming services such as Qobuz, Deezer or Napster.
CloudyX CL-250W A98 Amplificateur WiFi DLNA AirPlay2 Bluetooth 5.0 HDMI 2x100W 4 Ohm CloudyX CL-250W A98 Amplificateur WiFi DLNA AirPlay2 Bluetooth 5.0 HDMI 2x100W 4 Ohm
1ON/OFF Switch
2Volume / Function button
3WiFi input LED indicator
4Bluetooth input LED indicator
5Phono / AUX input LED indicator
6Optical input LED indicator
7Bass setting LED indicator
8Treble setting LED indicator
9IR Receiver
10External ground terminal
11Pairing / Reset button
12Optical Toslink input
13Jack 3.5mm input
14Phono MM input
15RCA output
16Update interface
17Power supply
18Right channel speaker terminal
19Left channel speaker terminal
20Mic reception antenna
21WiFi / Bluetooth reception antenna
Product typeAmplifier
Power2x 100W @ 4Ω
InputsWiFi
Bluetooth 5.0
1x Optical Toslink
1x Jack 3.5mm line input
1x Phono (MM) RCA
OutputsSpeaker terminals
1x Stereo RCA
THD0.05%
SNR95dB
AUX Input sensitivity1V
RCA Phono (MM) sensitivity5mV
RCA Output level1V
Supported sampling ratePCM up to 24bit 192kHz
Power supply32V DC 5A
Dimensions225 x 202 x 45mm
Weight1.3kg
Package1x CloudyX CL-250W A98
1x Power supply
1x RCA cable
1x Jack 3.5mm cable
1x RCA to Jack 3.5mm cable
1x Remote control
InputJack 3.5mm
InputWiFi
OutputSpeaker terminal
DAC / ADC ChipNC
Channel2 (Stereo)
Amplifier chipN/A
Power (W)100.0
The CloudyX CL-250W A98 is a versatile and powerful amplifier, extremely practical, especially because of its complete wireless reception. It...
