DAYTON AUDIO WF150A WiFi Bluetooth Multiroom Amplifier 2x75W 4 Ohm with IR Remote Control
DAYTON AUDIO WF150A Amplificateur WiFi Bluetooth Multiroom 2x75W avec Télécommande
The Dayton Audio WF150A is a powerful and robust amplifier with many features. It integrates the brand's Hi-Fly technology allowing remote control via a dedicated application.
By buying this product you get 39 loyalty points
Reference : 13477
399,00 €tax incl.
332,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Attention: The product is delivered configured in 110V. If your electrical network provides a voltage of 220V (Europe), it is imperative to configure the device in 220V using the switch on the back of the device before connecting it to the mains. An incorrect setting could damage your device.
Dayton Audio WF150A
WiFi Bluetooth Multiroom Amplifier 2x75W with IR Remote Control
Dayton Audio WF150A Amplificateur WiFi Bluetooth Multiroom 2x75W avec Télécommande
The Dayton Audio WF150A is a powerful and robust amplifier with many features. It integrates the brand's Hi-Fly technology allowing remote control via a dedicated application. With 3 analog inputs, one SPDIF input, one Ethernet input and support for WiFi and Bluetooth as well as a subwoofer output, the WF150A is versatile and convenient. It will allow you to offer your audio system wireless connectivity that opens the doors to audio streaming and multiroom.
For its amplification stage, the WF150A includes two TDA7294 transistors capable of delivering a significant power of 2 x 75W RMS at 4 Ohm while limiting distortion and noise. As for WiFi connectivity, there is an excellent LinkPlay module ensuring a very good throughput and excellent signal stability. In addition, an antenna for WiFi and a second for Bluetooth improve the wireless transmission of audio signals. Finally, for the headphone amplifier stage, the WF150A integrates an NJM 4556A chip allowing the use of high impedance headphones.
Your current audio system redefined
This WiFi amplifier is very easy to install. Simply connect the device to a pair of speakers and your network to enjoy your music and multiroom.
xxx
Multiroom
The WF150A allows you to play your audio files synchronously in different rooms of your home, for a totally smooth and transparent listening.
xxx
multi-channels
Would you prefer to be able to listen to different music in each room? The WF150A allows you to associate the music of your choice to each device, and this in a totally independent way.
xxx
Multi-users
Dayton Audio's amplifier also allows multiple users to control it to play multiple tracks in different rooms.
Your music your own way
Specially designed by Dayton Audio, the Hi-Fly mobile application allows you to control compatible devices (such as this WF150A) remotely via WiFi, and enjoy the full multiroom experience. This allows you to stream your favorite music services, enjoy your music stored on your device or fetch your files available on your computer or on a USB stick connected to the amplifier. Thus, the application allows you to enjoy all the features of the WF150A in the simplest way possible.
xxx
Convenience
Control the amplifier using your smartphone or IR remote control.
xxx
Connectivity
The dual high gain antenna improves reception distance.
xxx
Hi-Res Audio
Enjoy your high definition audio files using the Optical Input.
Super simple setup
Configuring the WF150A is child's play. First you need to download the free iEast application available on the Play Store (Android) or the App Store (iOS). Once installed, open the application and let yourself be guided step by step through each instruction.
Note: If the device is connected in Ethernet then it is not necessary to perform the configuration steps proposed by the application. Just open the application and enjoy your music.
Product typeIntegrated amplifier
Inputs3x Stereo RCA
1x Optical Toslink
1x Ethernet RJ45
WiFi
Bluetooth
Outputs1x RCA Subwoofer output
Speaker terminals
Output power2x75W RMS @ 4 Ohm
Input sensitivity630mV
Frequency response20Hz-20kHz +/-75dB
Distortion0.1% THD
SNR88.6dB A-Weighted
Bass settings+/-6dB @ 100Hz
Treble settings+/-6dB @ 10kHz
Max consumption272W
Standby consumption7.5W
Dimensions432 x 260 x 59mm
Weight6.5kg
Package1x Dayton Audio WF150A
1x IR Remote Control
1x Power supply
The Dayton Audio WF150A is a powerful and robust amplifier with many features. It integrates the brand's Hi-Fly technology allowing remote...
