DAYTON AUDIO WF40A Amplifier Multiroom WiFi 2x20W with IR Remote
Dayton Audio offers with the WF40A a small WiFi amplifier extremely easy to set up. Just plug in a pair of speakers and enjoy your music. But the device offers much more than its ease of use, since it also offers multiroom, multi-channel and multi-user.
Reference : 13070
119,00 €tax incl.
99,17 € tax excl.
Dayton Audio WF40A
Multiroom Amplifier WiFi 2x20W with IR Remote Control
Dayton Audio WF40A Amplificateur Multiroom WiFi 2x20W avec Télécommande IR
The WF40A, an amplifier for the home
Multiroom
The WF40A allows you to play your audio files synchronously in different rooms of your home, for a totally smooth and transparent listening.
Multi channels
You prefer to listen to different music in each room? The WF40A allows you to associate the music of your choice to each device, and this in a completely independent way.
Multi users
Dayton Audio's amplifier also allows multiple users to control it to play multiple tracks in different rooms.
Take control
The iEast mobile application allows you to control compatible devices (like this WF40A) remotely over WiFi, and enjoy the full multiroom experience. It allows you to stream your favorite music services, enjoy your music stored directly on your device, or even fetch your available files on your computer or on a USB stick connected to the WF40A. Thus, this application allows you to enjoy all the features of the amplifier in the simplest way possible.
Compact & Polyvalent
Compact yet not lacking in power, this amplifier will be suitable in many situations.
Simple d'utilisation
The WF40A is controlled directly from a smartphone or via the supplied IR remote control. Pretty practical!
When simplicity rhymes with efficiency
Configuring the WF40A is child's play. First you need to download the free iEast application on the Play Store for Android or on the App Store for iOS. Once installed, open the application and let yourself be guided step by step through each instruction.
Output power2x20W RMS / 2x40W Max 8 Ohm
OS CompatibilityMac OS, iOS, Androidn, Windows
Supported protocolsDLNA
Airplay
WiFi801.11 b/g/n
Frequency response20Hz - 22kHz
SNR< 94.5dB
THD0.0005%
Crosstalk< 94.1dB
Supported file formats3AMP3, WMA, AAC, AAC+, Apple LOssless, FLAC, APE, WAV
Supported radio filesStreaming MP3, CMA, AAC
Power supplySupplied (But requires 2 pole US to FR adapter, available as accessory)
InputRJ45
InputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Power (W)20.0
Dayton Audio offers with the WF40A a small WiFi amplifier extremely easy to set up. Just plug in a pair of speakers and enjoy your music. But the...
