POPPULSE T150 CE 2015 Amplifier Class T TRIPATH TA2022 2x60W / 8 Ohm
4.6 / 5
By buying this product you get 22 loyalty points
Reference : 3626
229,00 €tax incl.
190,83 € tax excl.
NEW MODEL
Successor to the T150 PRO model of the POPPULSE T150 CEremains a reference in the art of exploiting the potential of the famous chipset TRIPATH TA2022, true legend of the DIY surrounded for the occasion of a plethora of guests of brands:
- Bipolar Electrolytic Capacitors Alpine Elnafor Audio applications.
- Duo of operational amplifiers LM-4562, which constitute the ultimate in AOP in the form of an integrated circuit (very low noise and distortion with a THD + N to 0.00003% , Common Mode Rejection (CMRR) and Power Supply (PSRR) cap at 120dB)
- High precision volume controller ALPS RK27non-motorized, a reference that no longer needs to be presented
-Oversized Toroidal Power Supply in replacement of the conventional switched-mode power supplies generally encountered on this type of Class-T product, and which makes it possible to limit the harmful effects of switching and of their harmonics on high frequencies.
Integrated amplifier polymorphic, the T150 CE develops with this arsenal a "small" 60 Watts per channel under 8Ω in Stereo mode, a power that, although seemingly limited,nt to surprise by its immediate availability.
But the real benefit of this new version lies in its ability to function as a mono bridged power block , a mode now usable both on the input XLR balanced than on one of theRCA asymmetric .
The cumulative power then reaches 90 Watts under 8Ω , of what to discipline the most indomitable enclosures.
Subtle mix of finesse and firmness, this amplifier of great generosity provides joy and emotion as few others know how to do in these tariff waters.
Caution this unit is not suitable for powering 4 ohm speakers in bridged mode
Features:/ Strong>
  • Class -T amplifier circuitTRIPATH TA2022
  • capacitorsAlpine Elna, AOP National SemiconductorLM-4562
  • High Precision Volume Controller ALPS RK27 "Blue Beauty"(disconnectable in "power amplifier" mode)/ Li>
  • Ability to operate in Mono 150Watts bridged
  • Line Input Stereo Line Out RCA asymmetric
  • Mono line input on socket RCA Asymmetric orXLR Symmetric
  • High quality RCA headers gold plated 24k
  • Outputs on HP terminals High Quality gold plated 24k and accepting cables of large cross-section
Warning, this amplifier may be sensitive to interference from radio equipment such as tuners./ P>
Specifications:
  • Channel Output Power:
    Stereo 2 x 60W / 8Ω (0.1% THD + N)
  • "Audiophile" power:
    Stereo 2x45W / 8Ω (0.015% THD + N)
    Mono Bridge 1 x 90W / 8Ω (0.1% THD + N)
  • Total Harmonic Distortion Rate: 0.05% (1 KHz)
  • Frequency Response: 15-80 KHz (-1db)
  • Signal Ratio Noise: 92dB
  • Sensitivity Input Line: 200mV
  • Yield: Up to 90%
  • Power supply: AC 110V-230V (± 10%) 50 / 60Hz
  • Maximum Power Consumption: 120W
  • Dimensions: 250 x 160 x 60mm (L x W x H)
  • Weight: 4.5Kg
https://www.audiophonics.fr/images2/3626/3626_T150CE-1.jpg
[Img-9635-left-thickbox_default]
https://www.audiophonics.fr/images2/3626/3626_T150CE-4.jpg
22 reviews
Bien mais pas révolutionnaire....
Bonjour
Bonne ampli voir très bonne ampli pour ce tarif je ne connais rien de mieux en neuf (à ce tarif)
Mais à la lecture des autres avis je pense que vous êtes pas habitué au matériel professionnel de monitoring...
Ce Poppulse à une réponse linéaire certes mais ...
Un S/N particulièrement pourri, en claire il et bruité ,sur enceintes à faible rendement cela pose pas de problème mais sur du haut rendement ont oubli direct
Les médium sont sympa et les aigu agréable mais pas très précis il oubli de nombreux micro détail
Et concernant les basse il est énergique mais non amortis (très faible tamping factor)
Donc basse légèrement monoton ,imprécise,mais bien présente donc plaît au plus grand nombre ....
Tester sur 1 ans donc bien-sûr rodé, et sur de nombreuses enceintes pro et grand public
Sur JBL de monitoring est genelec ont oubli ,basse de merde ( caricaturale) et aiguë imprécis
En multi amplification sur grosse JBL haut rendement, sur les voix basse on oubli (15pouces)cela fonctionne mais c clairement gras , sur les vois médium (300-4000) pas mal ,sur les aigu (chambre de compression )doux ,imprécis est surtout bruité.
Sur des sampan 310 ,sympa ressemble à un ampli hifi haut de gamme, basse énergique ( mais un peux caricaturale) med est aigu sympa pour une écoute domestique
Ma description peut semblé négative mais honnêtement c'est un bonne ampli surtout en regard du tarif ,la majorité des ampli de salon qui sont passés dans mon studio on fait largement moins bien que ce petit Poppulse
Mais comparé à certains lab gruppen ou chevin
Il ce fait clairement atomisé sauf sur le prix
Ets j'ai testé également un smsl sa160 ,bon la pour être clair passer votre chemin sauf si vous aimez le boom boom ....
This review has been posted for POPPULSE T150 CE 2015 Amplifier Class T TRIPATH TA2022 2x60W / 8 Ohm
Rien à dire et rien à ajouter.
Excellent ampli!
Allez-y, c'est tout bon!
Je possède ce produit depuis plusieurs mois et j'en suis ravi. Je l'ai fait upgradé et l'ouverture sonore en a été encore améliorée. Si je le vends aujourd'hui c'est uniquement parce que j'ai acheté un ampli Thierry CLER qui est phénoménal. En tout cas, pour le prix, ce petit ampli numérique en remontre à bien nombre d'ampli reconnus. J'ai trouvé seulement un problème de mise en sécurité sur des panneaux MAGNEPAN anciens qui descendent très bas en impédance (moins de deux ohms) sinon il tenait mes voix du théâtre (ALTEC avec boomer de 40cm) ainsi que des GKF 505 (boomer de 38cm) sans le moindre souci. A conseiller sans modération.
le résultat est excellent, nettement supérieur a une carte externe usb phase 26 terratec normalement bien appréiée.
Bonjour
J'ai fais l'acquisition de cet ampli pour l'associer à une paire de BC Acoustique Niger et le résultat est au TOP. Très bonne musicalité, détail sonore, puissance ... aucun regret. La livraison a été faite très rapidement, moins d'une semaine pour le réceptionner en Guadeloupe.
