WONDOM A2100 V2 Class D 2.1 Amplifier Bluetooth 2x 100W / 6 Ohm
2.8 / 5
Reference : 12109
85,00 €tax incl.
70,83 € tax excl.
Wondom A2100
Class D Amplifier 2x100W 6 Ohms
amplificateur class d 2x100w wondom a2100
Wondom, a subsidiary of the renowned electronics manufacturer Sure, offers with its A2100 amplifier a versatile system capable of delivering 2x100W under 6 Ohms, with excellent efficiency.
Compact but efficient
If it is so effective, it is also its great versatility. In fact, it integrates both a Micro USB input, a stereo RCA input, an Optical SPDIF input and a 3.5mm jack input (on the front panel), and will also allow you to play your music directly from your sofa via Bluetooth. It will also be ideal for headphone listening, with its 3.5mm jack output on the front panel.
In addition, if necessary, you can connect a subwoofer for a bass boost, whose level is adjustable directly at the rear of the amplifier.
IR Remote Control
Wondom offers an infrared remote control for remote control of the A2100. This will allow you to turn the amplifier on/off, adjust the volume, change channels and sources. A real gain in terms of user comfort.
télécommande sure wondom a2100
Wondom A2100 review by Qobuz
" Compact, powerful and offering more than good sound performance, with two analog inputs, an optical digital input and a Bluetooth link, the Sure Explorer A2100 amplifier can form the heart of a Hi-Fi system that combines the modernity of Bluetooth transmission with a certain tradition of other sources that can be connected to it. "
Test Qobuz
Connectors : Inputs
RCA Stereo1x
SPDIF Optical1x
Micro USB1x
Jack 3.5mm1x
BluetoothClass 2
Connectors : Outputs
RCA for Subwoofer1x
Jack 3.5mm1x
Speakers output-
Output power2x100W 6 Ohms
TypeClass D
Efficiency> 90%
Input sensitivityAt 6Ω 100W 1kHz, Jack 3.5mm : 294mV
At 6Ω 100W 1kHz, RCA : 496mV
Sampling rateUp to 96kHz
THDAt 6Ω 100W 1kHz Jack 3.5mm : 0.05%
At 6Ω 100W 1kHz RCA : 0.042%
Output noise620uV
SNR82W at 6Ω THD+N 1% RCA : 82dB
ProtectionsOver/undervoltage
Overcurrent
Temperature
Power SupplyJack 5.5/2.5 DC 12V at 36V
Dimensions21 x 12.5 x 4.8cm
Power supply24V 5A (not included)
AccessoriesIR Remote Control
wondom a2100
wondom a2100 schéma
The volume knob also allows you to change the source by pressing and turning the source.
InputJack 3.5mm
OutputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
Power (W)100.0
5 reviews
Souffle
Gros problème de souffle. Audiophonics a repris ce produit sans problème mais n'a pas réussi à le remplacer par un modèle ne présentant pas ce défaut. Je suis étonné que ce produit soit encore en vente sur le site.
This review has been posted for WONDOM A2100 V2 Class D 2.1 Amplifier Bluetooth 2x 100W / 6 Ohm
No power supply and broken remote
The amplifier sounds great (I've listened with Indiana Line 240 speakers) but I received the box without power supply and the remote control is not working at all.
I have already received the "incident ticket", but it's really annoying to go back to post office ... and hope that it will be sorted out.
Attention avec un bémol !
Cinq étoiles quand même!.
A la fois redoutable de précision et de justesse, exécrable dans les " "boom boom" les mauvaises basses vendus par des David Guetta.
Tout dépend de la source, j'entends par là la qualité de l'enregistrement ou le mixage. Et comme je privilégie la source directe cela ne pardonne pas. Meilleurs résultats en acoustique pure , classique , jazz , blues et j'en passe , j'ai quand même pris mon pied vulgairement parlant. Donc les mixages de prise de sons de prétendu pro. à bannir car ce petit ampli mine de rien révèle les mauvaises notes (canards).
Parfait
Marche très bien avec mes enceintes Dali Zensor Pico.
cailloux
c'est la première fois que je suis déçu par ce site.... aucun aigu
que du grave . mes enceintes Quad ESL2905 font vraiment un bruit de boite a chaussure, même si je ne l'avais pas acheté pour écouter de la musique avec ces enceintes. je vais voir avec audiophonics pour le retourner
Bonjour,
Si la sonorité de cet amplificateur ne vous convient pas, vous pouvez bien entendu nous contacter pour effectuer une demande de retour.
Merci.
