Superbe ampli, je les préfères à mes anciens fosi v3 mono. Livraison rapide au Canada. Avec le support de 3e audio j’ai réussi à régler le problème du auto-standby trop sensible. Maintenant c’est parfait.
By buying this product you get 23 loyalty points
3E Audio, a recognized player in the DIY world, now offers a Class D mono amplifier incorporating audiophile Hi-Fi components. The A7 Mono amplifier is based on one TI TPA3255 chips in PBTL configuration, and a dual OPA1656. This means it can deliver up to 1x 260W into 4 ohm power.
In terms of connectors, the 3E Audio A7 mono features an RCA input, a practical balanced XLR/Jack 6.35mm combo input, and an output on speaker terminals. The RCA input gain can be adjusted (LOW=26dB, HIGH=29dB), and the preamplifier stage and volume control can be bypassed for use as a power amplifier. Versatile and high-performance, this little amplifier is able to offer a good reserve of power while preserving the final sound reproduction.
In response to feedback from the Audio Science Review community, 3E Audio has made a number of modifications to its amplifiers.
A7
A7se
A7 Mono
A5se
A5
Amplification chip
2x TPA3255
2ch - PBTL
1x TPA3255
2ch - BTL
1x TPA3255
1ch - PBTL
1x TPA3251
2ch - BTL
2x TPA3251
2ch - PBTL
Output power
(4 ohm, THD+N=1%)
2x 250W
2x 230W
1x 260W
2x 140W
2x 150W
Output power
(8 ohm, THD+N=1%)
2x 140W
2x 130
1x 150
2x 70W
2x 80W
Load impedance
2-16 ohm
4-16 ohm
2-16 ohm
4-16 ohm
2-16 ohm
The TPA3255 amplifier chips offer a consistent level of output power, as the 3E Audio A7 mono delivers up to 1x 260W into 4 ohm and up to 1x 150W into 8 ohm (THD+N = 1%). In addition, the PBTL configuration maintains continuous, stable output power while reducing power losses. It also enables the amplifier to withstand loads of up to 2 ohms.
The preamplifier stage of the 3E Audio A7 Mono is made up of a dual OPA1656 OPAs mounted in DIP 8 and easily replaceable with pliers, thanks to the design of the case. In fact, the OPAs can be accessed through two hatches without opening the case. Here's a non-exhaustive list of compatible OPAs: OPA1656, OPA1602, OPA2134, NE5532P, LME49720, LM4562, MUSES02, MUSES8920, NJM4580, NJM4556, NJM2068, OP249, AD827, etc.
Please take care not to damage the device or the OPAs when replacing or handling them. Any damage to the device caused by improper handling by the user (reverse mounting of OPAs, mounting of non-compatible OPAs, etc.) will invalidate the product warranty. Please refer to the manual to carry out the operation.
Rubycon capacitors meet high current requirements, reducing noise and improving THD.
The coils used in the amplifier provide improved linearity and reduced distortion, while delivering the best performance whatever the load.
These highly reliable LC filter capacitors ensure optimum audio performance.
1 | Left channel status LED |
2 | RCA input status LED |
3 | Multifunction button |
4 | XLR input status LED |
5 | Right channel status LED |
6 | Balanced XLR/Jack 6.35mm combo input |
7 | RCA input |
8 | RCA gain control |
9 | Speaker terminal output |
10 | Volume bypass |
11 | 38V-52V DC power supply via DC jack |
"If my memory serves me right, 3e audio was the first company to bring us high performance TI TPA3255 class D amplifiers with PFFB. While they have more competition now, it is clear they intend to stay on top of this game, squeezing every bit of performance out of this architecture, while providing nice feature set. We are talking high performance, high power amplifiers that are tiny yet deliver what people need in most cases. I am happy to recommend 3e audio A7 / A7 Mono stereo audio amplifiers."
Product type | Class D amplifier |
Channels | Mono |
Amplification chip | 1x TI TPA3255 |
OPA | Dual OPA OPA1656 |
Structure | PFFB |
Inputs | 1x Single-ended RCA input 1x Balanced XLR/jack 6.35mm combo input |
Output | 1x Speaker terminal output |
Input impedance | RCA : 10KΩ XLR/TRS : 20KΩ |
Volume attenuation | -50dB |
Volume bypass | |
RCA gain control |
Audio specifications (RCA IN) | |
THD+N (5W) | 0.0007% @ 4Ω 0.0006% @ 8Ω |
SNR (1% THD+N, 1KHz, A-wt) | 123dB |
Dynamic range (1% THD+N, 1KHz, A-wt) | 123dB |
Frequency response (±0.5dB) | 20Hz-30KHz |
Noise (A-wt) | < 20uVrms |
Crosstalk | -120dB |
Gain | 26dB / 29dB |
Input sentivity | 1.75Vrms |
Output power (1% THD+N) | 1x 480W @ 2Ω 1x 260W @ 4Ω 1x 150W @ 8Ω |
Output power (10% THD+N) | 1x 600W @ 2Ω 1x 320W @ 4Ω 1x 200W @ 8Ω |
Output impedance | 2Ω-16Ω |
audio Specification (XLR IN) | |
THD+N (5W) | 0.0006% @ 4Ω 0.0005% @ 8Ω |
SNR (1% THD+N, 1KHz, A-wt) | 126dB |
Dynamic range (1% THD+N, 1KHz, A-wt) | 126dB |
Frequency response (±0.5dB) | 20Hz-35KHz |
Noise (A-wt) | < 15uVrms |
Crosstalk | -130dB |
Gain | 20dB |
Input sensitivity | 3.5Vrms |
Power supply | 38V-52V DC 5A/9A (The supplied power supply operates on 110V and 230V) |
Power consumption | OFF: < 0.4W ON (no audio): 6W |
Dimensions | 170 x 168 x 46mm |
Weight | 1000g |
Package | 1x 3E Audio A7 Mono amplifier 1x 48V 10A mains adapter |
Input | Jack 6.35mm |
Input | RCA |
Input | XLR |
Output | Speaker terminal |
Color | Black |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 260.0 |
Remote Control | No |
Average votes 4.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jean-francois L.
Peter P.
