AIYIMA D03 Full Digital Amplifier FDA 2.1 TAS5624 Bluetooth 5.0 aptX HD 2x120W 4 Ohm
Aiyima's D03 is an FDA (Full Digital Amplifier) amplifier offering a nice energy reserve as well as a precise and transparent sound reproduction. It is indeed capable of developing no less than 2x120W under 4Ω (THD+N 1%) with a high efficiency, thanks to a TI TAS5624A amplifier chip.
4.9 / 5
Reference : 15692
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 26-05-2026.
Aiyima D03
Full Digital Amplifier FDA 2.1 TAS5624A Bluetooth 2x120w 4 Ohm
Aiyima D03 Amplificateur FDA 2.1 TAS5624A Bluetooth 2x120W 4Ω
Aiyima's D03 is an FDA (Full Digital Amplifier) amplifier offering a nice energy reserve as well as a precise and transparent sound reproduction. It is indeed capable of developing no less than 2x120W under 4Ω (THD+N 1%) with a high efficiency, thanks to a TI TAS5624A amplifier chip. It also benefits from a particularly complete connectivity, with USB-B, Optical Toslink, Coaxial, stereo RCA (ADC PCM1808) as inputs, but also a Bluetooth 5.0 reception. Practical, this last one allows to diffuse remotely its music, from a smartphone, while taking advantage of the high resolution Bluetooth codecs aptX and aptX-HD. On the output side, there are of course speaker terminals but also an output for active subwoofer, on RCA connector.
Product typeAmplifier
Amplifier typeFDA
Output power2x120W @ 4Ω, 32V, 1% THD+N
2x60W @ 8Ω, 32V, 1% THD+N
2x140W @ 4Ω, 32V, 10% THD+N
2x75W @ 8Ω, 32V, 10% THD+N
InputsBluetooth 5.0
1x USB-B
1x Optical Toslink
1x Coaxial
1x Stereo RCA
OutputsSpeaker terminals
1x RCA output for active subwoofer
Amplification chipTAS5624A
ADC chipPCM1808
SPDIF InterfacesCS8422
TAS5548
Bluetooth chipQCC3034
Supported Bluetooth codecsAAC, SBC, aptX, aptX-LL, aptX-HD
Supported sampling ratesPCM up to 24bit 192kHz
USB CompatibilitéWindows XP / 7 / 8 10
Mac OS
Linux
OTG smartphones
SNR93dB
Bass / Treble settings±14dB
Input sensitivity0.775V
Frequency response20Hz-20kHz (±1.25dB)
Subwoofer output level2.1V
THD0.001% (1kHz, 1W)
Speaker impedance4-8Ω
Supply voltage24 - 36VDC on DC 5.5/2.5mm jack (32V 5A power supply included)
Dimensions151 x 141 x 37mm
Weight670g
Housing materialAluminum
Package1x Aiyima D03
1x Power supply
1x Bluetooth antenna
1x Remote control
1x USB Cable
1x Optical cable
OutputSubwoofer
OutputSpeaker terminal
Channel2.1
ClassFDA
Amplifier chipTAS5624
Power (W)120.0
Remote ControlYes
16 reviews
Bon ampli dans l'ensemble
Après quelques mois d'utilisation voici mon avis.
Je l'utilise principalement relié à l'ordinateur en USB et en Bluetooth avec un smartphone Samsung récent. Dans les deux cas je trouve la qualité du son très bonne.
Il y a deux point qui pourraient être améliorés:
1- La télécommande infrarouge est très directive, si il y a le moindre objet entre la télécommande et le récepteur, ça ne fonctionne pas.
2- La progressivité du Volume n'est pas bien faîte, il faut tourner beaucoup le bouton pour vraiment changer le volume.
A part ça, et ce qui compte le plus, la qualité sonore est au rendez-vous pour moi.
This review has been posted for AIYIMA D03 Full Digital Amplifier FDA 2.1 TAS5624 Bluetooth 5.0 aptX HD 2x120W 4 Ohm
Better than expected
6/5 so far! I was trying to find decent all arounder to my small living room for playing music over bt with an option to hook it on tv for watching movies or playing games. This small device had the connection option and a remote for this. Paired the device with yamaha ns-50f speakers and jamo 200 sub which plays out superb IMHO. Hope the product lasts better better than my old yamaha amp (holy smoke got out after 4y)
Excellent Ampli
D'abord j'ai été agréablement surpris par le poids de ce petit carré de 15cm très lourd, ce qui n'est certes pas un argument de qualité sonore mais gage de qualité de construction.
Connecté en USB sur mon vieux MacBookPro de 2012, les premiers essais ne furent pas bons, mais il faut jouer sur les seules réglages possibles "Bass and Trebble".
Pour mon installation secondaire de bureau (enceintes biblio Highlands Oran 430I et petit caisson de grave BW) j'ai mis -4 en aiguë et +8 en basse et là je fus très agréablement surpris par la qualité sonore globalement.
En résumé, je suis très satisfait de mon achat et merci à Audiophonics !
Entière satisfaction !
Sur les conseils de Monsieur Aubert, j'ai commandé ce petit ampli, c'est une grande satisfaction le son est bon je me fais plaisir, le bluetooth est étonnamment bon et je ne perçois pas de différence avec la liaison directe par USB, j'écoute des fichiers FLAC non compressé en qualité CD minimum. Le son est neutre clair. Le bluetooth fonctionne très bien on a les boutons pour changer entre le bluetooth USB , l'optique, etc... La télécommande est un peu directive il faut être en face pour que ça fonctionne.
Pas cher mais pas grand chose...
Fonctionne très bien, simple et efficace.
Par contre il n'y a pas d'aigu c'est un peu frustrant...
Aiyima's D03 is an FDA (Full Digital Amplifier) amplifier offering a nice energy reserve as well as a precise and transparent sound...
