AIYIMA D03 Full Digital Amplifier FDA 2.1 TAS5624 Bluetooth 5.0 aptX HD 2x120W 4 Ohm
Aiyima's D03 is an FDA (Full Digital Amplifier) amplifier offering a nice energy reserve as well as a precise and transparent sound reproduction. It is indeed capable of developing no less than 2x120W under 4Ω (THD+N 1%) with a high efficiency, thanks to a TI TAS5624A amplifier chip.
4.8 / 5
Reference : 15692
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 03-10-2025.
Aiyima D03
Full Digital Amplifier FDA 2.1 TAS5624A Bluetooth 2x120w 4 Ohm
Aiyima D03 Amplificateur FDA 2.1 TAS5624A Bluetooth 2x120W 4Ω
Aiyima's D03 is an FDA (Full Digital Amplifier) amplifier offering a nice energy reserve as well as a precise and transparent sound reproduction. It is indeed capable of developing no less than 2x120W under 4Ω (THD+N 1%) with a high efficiency, thanks to a TI TAS5624A amplifier chip. It also benefits from a particularly complete connectivity, with USB-B, Optical Toslink, Coaxial, stereo RCA (ADC PCM1808) as inputs, but also a Bluetooth 5.0 reception. Practical, this last one allows to diffuse remotely its music, from a smartphone, while taking advantage of the high resolution Bluetooth codecs aptX and aptX-HD. On the output side, there are of course speaker terminals but also an output for active subwoofer, on RCA connector.
Product typeAmplifier
Amplifier typeFDA
Output power2x120W @ 4Ω, 32V, 1% THD+N
2x60W @ 8Ω, 32V, 1% THD+N
2x140W @ 4Ω, 32V, 10% THD+N
2x75W @ 8Ω, 32V, 10% THD+N
InputsBluetooth 5.0
1x USB-B
1x Optical Toslink
1x Coaxial
1x Stereo RCA
OutputsSpeaker terminals
1x RCA output for active subwoofer
Amplification chipTAS5624A
ADC chipPCM1808
SPDIF InterfacesCS8422
TAS5548
Bluetooth chipQCC3034
Supported Bluetooth codecsAAC, SBC, aptX, aptX-LL, aptX-HD
Supported sampling ratesPCM up to 24bit 192kHz
USB CompatibilitéWindows XP / 7 / 8 10
Mac OS
Linux
OTG smartphones
SNR93dB
Bass / Treble settings±14dB
Input sensitivity0.775V
Frequency response20Hz-20kHz (±1.25dB)
Subwoofer output level2.1V
THD0.001% (1kHz, 1W)
Speaker impedance4-8Ω
Supply voltage24 - 36VDC on DC 5.5/2.5mm jack (32V 5A power supply included)
Dimensions151 x 141 x 37mm
Weight670g
Housing materialAluminum
Package1x Aiyima D03
1x Power supply
1x Bluetooth antenna
1x Remote control
1x USB Cable
1x Optical cable
OutputSubwoofer
OutputSpeaker terminal
Channel2.1
ClassFDA
Amplifier chipTAS5624
Power (W)120.0
Remote ControlYes
12 reviews
Pas cher mais pas grand chose...
Fonctionne très bien, simple et efficace.
Par contre il n'y a pas d'aigu c'est un peu frustrant...
This review has been posted for AIYIMA D03 Full Digital Amplifier FDA 2.1 TAS5624 Bluetooth 5.0 aptX HD 2x120W 4 Ohm
exellent petit FDA
comme toujours commandé un matin avant 10h reçus le lendemain !! utilisation pour l'audio de mon PC en combinaison avec un dac SMSL SU-1 pour alimenter des petites enceintes avec un rendement proche des 85 db le DO3 se comporte très bien niveau alimentation et musicalement très neutre, comparé à mon Fosi audio V3 qui est plus puissant et plus pêchu je trouve le DO3 plus adapté à mon utilisation d'écoute de proximité
ses 2 modèles sont vraiment étonnants !
Le AIYIMA D03 est un très bon amplificateur classe D. Etant mon 4ème, celui-ci est le plus naturel et dynamique. Excellent, même à volume très élevé... Je l'utilise dans 25m2 sur un woofer SBAcoustics + tweeter à ruban + sub. La sortie sub passive est bonne, la sortie USB est largement supérieure à la sortie RCA. Je n'ai pas testé la Coaxiale ni l'Optique.
Comme il est dit dans un autre commentaire et sur certains forums anglo-saxons les basses sont fermes et profondes.
Une précision quand même, en le branchant la 1ère fois je me suis aperçu que les basses étaient poussées à +14db. Le S.A.V d'Audiophonics m'a fait savoir qu'il peut y avoir des modèles dont les réglages ne sont pas remis à zéro suite au contrôle qualité, donc à vérifier si vous évaluez votre D3 au premier branchement.
Très bonne qualité sonore pour le prix
Ce petit ampli a une qualité sonore très bonne pour sa taille et son prix. Je l'utilise avec des enceintes bibliothèque Focal. Je le recommande !
Petit ampli qui tient ses promesses
Malgré mes craintes au sujet des FDA et de leur absence de boucle de rétroaction avec pour conséquence un faible facteur d'amortissement, cet ampli dépasse mes espérance en terme de qualité sonore (malgré des enceintes bibliothèque relativement basiques)
L'utilisation via Bluetooth. aptx-hd est vraiment très bonne même si les entrées numériques sont permettent une diffusion encore plus qualitatives.
Il est installé dans une résidence secondaire et c'est juste parfait.
Je l'ai également testé sur des enceintes colonnes et avec un streamer node, le son est excellent.
Aiyima's D03 is an FDA (Full Digital Amplifier) amplifier offering a nice energy reserve as well as a precise and transparent sound...
