Amplifier Stereo Class D TPA3251 2x140W 4 Ohm
This affordable Class D amplifier is based on a TPA3251D2 amplification chip, delivering 2x140W at 4Ω with high efficiency. It will therefore have no difficulty driving most speaker models. In addition, it benefits from PurePath Ultra HD technology, maintaining a very low distortion level across the entire frequency range while offering excellent sound precision.
Reference : 21662
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 19-11-2026.
Class D Stereo Amplifier TPA3251 2x140W 4 Ohm
The amplifier features a solid build quality, using proven audio-grade components. The power stage notably uses two 50V 1000µF Nichicon capacitors for electrical signal filtering.
In terms of connectivity, this model remains simple, with a stereo RCA input, a 3.5mm AUX output, and of course speaker binding posts. This notably allows for a 2.1 channel system setup with an active subwoofer.
Technical Specifications
Product typeAmplifier
Amplifier typeClass D
Input1x Stereo RCA
OutputsSpeaker binding posts
1x 3.5mm AUX jack
Impedance4-8Ω
Amplification chipTPA3251D2
Power2x 80W @ 8Ω, THD+N 1%, BTL, 36V
2x 140W @ 4Ω, THD+N 1%, BTL, 36V
2x 175W @ 3Ω, THD+N 1%, BTL, 36V
2x 35W @ 8Ω, THD+N 1%, BTL, 24V
2x 65W @ 4Ω, THD+N 1%, BTL, 24V
2x 85W @ 3Ω, THD+N 1%, BTL, 24V
THD+N0.005% @ 1W 4Ω
PSRR60dB
SNR> 111dB (A-Weighted)
Dimensions180 x 104 x 42mm
Power supply24-36VDC (sold separately)
Weight542g
Package1x Stereo Class D Amplifier TPA3251
OutputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3251D2
Power (W)140.0
2 reviews
Tres bonne amplis rapport qualité prix le son et bon et il ne prend que peu de place sur une étagères, cependant j'ai eu une frayeur un jour en l'allumant je n'avais pas de voix droite, j'ai éteint puit rallumer l'ampli et tous est revenue. Apres avoir échanger avec le SAV j'ai appris que l'ampli peut ce mettre en secu sur chaque voix indépendamment, avoir une protection interne est donc tres rassurant !
This review has been posted for Amplifier Stereo Class D TPA3251 2x140W 4 Ohm
bon simple efficace.
ne fonctionne pas en 15 volt. En 20 volt si. Très bon grave. Tweaks possibles: virer les borniers haut-parleurs pour sortir des câbles depuis l’intérieur de l'appareil et également souder directement des câbles rca DIY en cuivre émaillé de petite section (déjà essayé sur smsl sa-50 avec gain qualitatif parfaitement audible).
Notez que sur batterie Li-on 20 volt 2A le gain par rapport à une alimentation 28 volts 5 A 'de laboratoire' n'est pas évident à discerner sur enceintes haut-rendement transparent, ... peut-être dans le grave mais pas assez de temps d"écoute pour l'instant. En tout cas l'ampli ne laisse pas passer le bruit résiduel de l'alimentation secteur, le medium aigu reste très bon. Merci Bonnes écoutes à tous.
This affordable Class D amplifier is based on a TPA3251D2 amplification chip, delivering 2x140W at 4Ω with high efficiency. It will therefore have...
