By buying this product you get 86 loyalty points
Class D Amplifier with Integrated DSP 2x560W / 1x 1150W
The APA1200DSP from Dayton Audio is a powerful and versatile Class D amplifier capable of delivering 2x 560W or 1x 1150W. It is equipped with a DSP processor that offers complete control over every aspect of sound reproduction, via an intuitive and ergonomic interface. This DSP includes an equalizer, filters, phase adjustment and delay management.
With a very low noise level and high power output, the APA1200DSP is a very efficient Class D amplifier. With no less than 2x 560W of power, or 1150W in bridge mode, the APA1200DSP will have no trouble accompanying the most demanding speakers.
The APA1200DSP is more than just an amplifier. The APA1200DSP is a full-featured digital engine with a DSP processor, including an 8-band EQ, limiter, phase and delay control, and adjustable crossover.
Setting up an audio system can sometimes be a daunting task when the unit is not located in your listening area. In addition to the front panel controls, the APA1200DSP's internal software offers complete control over every parameter via an intuitive and easy-to-use web interface. It works on any web browser, eliminating the need to install a mobile application or additional software. Multiple devices can be installed on the same network and profiles can be saved and transferred easily.
Auto EQ
Setup is easier than ever, as the APA1200DSP can automatically adjust a 5-band parametric equalizer to best suit the subwoofers being used and the room in which they are located. Just plug in the supplied microphone
8-band parametric equalizer
In addition to the automatic equalizer, the APA1200DSP has three additional equalization bands for a total of eight bands. Each band is variable over a Q value of 0.4 to 14, a range of 20Hz to 20kHz and a gain of -12dB to +6dB. Each of the five bands controlled by the automatic equalizer can also be adjusted to function as a high pass/low pass or shelf filter.
Integrated limiter
With so much power, it can be easy to overpower speakers. The integrated limiter allows a complete control and protection of the speakers. It is possible to control the threshold, attack or release independently for each channel.
The APA1200DSP offers a complete and versatile connectivity. The input section accepts +4dB and -10dB line signals on single-ended RCA or balanced XLR, as well as SPDIF signals on Coax. Ensuring compatibility with most sources, these inputs are routed to XLR and RCA outputs for multi-zone or subwoofer setup. The two amplified channels can drive 2Ω, 4Ω or 8Ω speakers in stereo and can be bridged to drive 4Ω speakers at 1150W. The APA1200DSP also has an on-board Ethernet (RJ45) port for network connection, as well as a 12V trigger input and output for automated system integration.
Product type | Amplifier with integrated DSP |
Amplifier type | Class D |
Output power | Stereo : 2x 560W Bridge : 1x 1150W |
Inputs | 1x Balanced XLR 1x Single-ended RCA 1x Coaxial |
Outputs | 1x Balanced XLR 1x Single-ended RCA |
Input sensitivity | 0.316Vrms @ -10dBV 0.631Vrms @ -4dBV |
Max input level | 1.8Vrms |
Frequency response | 20Hz - 20kHz |
Frequency deviation (20Hz-20kHz) | 3dBrms |
SNR @ A-Weighted | > 96dB |
THD+N @ Rated power | 0.74% |
Auto on sensitivity | 10mVrms |
Supply voltage | 115-230VAC |
Consumption | Standby : < 2W Max : 1600W |
Dimensions | 432 x 381 x 95mm |
Weight | 7.35kg |
Color | Black |
Package | 1x Dayton Audio APA1200DSP 1x Power cable 1x Microphone 1x Mounting brackets |
Input | RCA |
Input | SPDIF |
Input | XLR |
Output | RCA |
Output | XLR |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 1000.0 |
