DAYTON AUDIO APA150 Class A/B Amplifier 2x75W 4 Ohm Black
The DAYTON AUDIO APA150 from 2x75W on 4 Ohm is the perfect integrated amplifier from in a small aluminum housing. Powerful and musical, it offers a real solution that is very easy to use with a stereo input.
By buying this product you get 25 loyalty points
Reference : 12601
259,00 €tax incl.
215,83 € tax excl.
This product is temporarily unavailable.
Warning, before connecting this amplifier you must select the power option matching your electrical network (220V or 110V).
Dayton Audio APA150
Amplifier Class A/B - 1x150W 8 Ohm - 2x75W 4 Ohm
Dayton Audio APA150 Amplificateur de bureau Class A/B 1x150W 8 Ohm 2x75W 4 Ohm
High fidelity and power
The Dayton Audio APA150 2x75W on 4 Ohm is the perfect integrated amplifier from in a small aluminum housing. Powerful and musical, it brings a real solution of great ease of use with a stereo input, a power button and a volume on the front. It thus brings for a soothed budget, the capacity to control speakers libraries and speakers columns of quality.
Dayton Audio APA150
HIFI quality design
The Dayton Audio APA150 has an "old fashioned" design with discrete transistor components on its path with a toroidal transformer for realistic dynamics. Its refined design allows it to produce a particularly attractive and musical sound for an affordable budget of a disconcerting ease of use.
Mono mode and adjustable active filter
The Dayton Audio APA150 has an active filter adjustable from 50Hz to 150Hz allowing it to be transformed into an amplifier for subwoofer. The mono mode button allows 150w on one channel to drive a single bass speaker for example. The amp has a 15-minute auto sleep mode that can be disengaged.
Dayton Audio APA150
Dayton Audio APA150 review by Qobuz
" The Dayton Audio APA150 amplifier is a serious device that keeps its appearance and sound reproduction from being blurred, powerful and well-structured at the bottom of the spectrum, and benefits from a clever technical design. "
Test Qobuz
Review and measurements of the Dayton Audio APA150 by Audio Science Review
The Dayton Audio APA 150 performs along the lines that we have sunk into in budget amplifiers. No doubt with good speakers and content, the APA 150 will provide an enjoyable experience. "
Test et mesures du Aune X1s 10th Anniversary par Audio Science Review
ClassA/B
Stereo output power2x75W 4 Ohm
Mono output power1x150W 8 Ohm
Inputx1 RCA
OutputSpeaker terminal
Input impedance47 KOhms
Power supply110V or 230V (Adjustable switch)
SNR100dB
Active adjustable filter50Hz - 150Hz
Weight6kg
Dimensions170 x 174 x 392mm
Power cableInclued
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipLM324
Power (W)150.0
2 reviews
Utilisation stappé en Mono
Je l'utilise pour alimenter mes Transducteurs Clark Synthesis, il est parfaitement adapté. Fréquence de coupure réglable, strappé en Mono, il est parfait.
This review has been posted for DAYTON AUDIO APA150 Class A/B Amplifier 2x75W 4 Ohm Black
Un OVNI HIFI
Alors , et bien c'est la main de fer dans un gant de velours, très puissant et charpenté, le médium aigu est bien là aussi.
Un Nad 316 bee mk2 est largué par cet ampli deux fois moins chère.
Impossible de mettre le bouton de volume au tiers, sinon les voisins vous tue !!!! (enceintes Mission 733 pro MK2 , Klipsch référence)
Musical, et bien foutus bravo, c'est adopté !!!
Recommandé !!!
Gilles
The DAYTON AUDIO APA150 from 2x75W on 4 Ohm is the perfect integrated amplifier from in a small aluminum housing. Powerful and musical, it offers a...
