DAYTON AUDIO DTA-2.1BT2 Class D 2.1 Amplifier Bluetooth with Tone Control 2x50W + 100W 4 Ohm Black
The Dayton Audio DTA-2.1BT2 is a discrete amplifier capable of accompanying two speakers and a subwoofer. This makes it possible to create a compact 2.1 system, regardless of the size of your listening room. The 2x50W output power is more than enough for the majority of library speakers.
Reference : 13622
149,90 €tax incl.
124,92 € tax excl.
Grantie 5 ans
Please note that the mains cable supplied with the product is a US cable. You need this accessory to use it in France: 2-pin USA power adapter to FR plug.
DAYTON AUDIO DTA-2.1BT2 Amplificateur 2.1 Class D Bluetooth avec Contrôle de Tonalité 2x50W + 100W
The Dayton Audio DTA-2.1BT2 is a discrete amplifier capable of accompanying two speakers and a subwoofer. This makes it possible to create a compact 2.1 system, regardless of the size of your listening room. The 2x50W output power is more than enough for the majority of library speakers and the 100W subwoofer output is perfectly suited for a small subwoofer. To be able to deliver such a high power in such a small format, the DTA-2.1BT2 uses a Class D amplification allowing to obtain a very high efficiency.
On the connectivity side, the DTA-2.1BT2 is equipped with the 3 most common audio inputs: Jack 3.5mm, RCA Stereo and Bluetooth. The latter is ideal for listening to your favorite songs from your sofa by sending your playing your audio files from your smartphone.
The front panel of the DTA-2.1BT2 has 4 rotary knobs. The leftmost one allows the subwoofer's cut-off frequency to be set between 50 and 120Hz for precise adjustment of your system. The second knob adjusts the level of the subwoofer output. The following one allows a tone control to adapt the playback to your system and listening room. Finally, the last one corresponds to the general volume of the amplifier. Of course, there is also a push button that allows you to switch the unit on/off or change the source.
All the components of this DTA-2.1BT2 are integrated in a beautiful and robust black brushed Aluminium case, which will integrate visually without any problem in the vast majority of audio systems.
Product typeAmplifier
Amplifier chipTPA3116
Amplification typeClass D
Power2x50W + 1x100W (subwoofer)
Impedance4-8 Ohm
Subwoofer crossover frequency adjustment50-120Hz
THD0.4% @ 25WPC
Bluetooth compatibilityA2DP, AVRCP
Power supply24V DC 4A (power supply included)
Dimensions129.5 x 152.4 x 38.1mm
Housing materialBrushed Aluminium
Package1x Dayton Audio DTA-2.1BT2
1x Bluetooth Antenna
1x Power supply (Requires a 2 poles USA power adapter to FR)
InputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
Channel2.1
Power (W)100.0
Power (W)50.0
2 reviews
Brilliant Amplifier
Great connectivity flexibility and good power reserve. Very functional for quick and simple set-up of music in the garden or on the terrace. Can use a few more of these.
This review has been posted for DAYTON AUDIO DTA-2.1BT2 Class D 2.1 Amplifier Bluetooth with Tone Control 2x50W + 100W 4 Ohm Black
Petit mais costaud
Il est raccordé à 2 comètes 202 TRIANGLE et un caisson DIY muni d’un HP de 25 cm (Monacor SPH 255) et le résultat est impressionnant largement suffisant pour sonoriser mon living à un niveau sonore plus que confortable, pas encore testé avec un CD, mais déjà super en Bluetooth avec mon smartphone .
The Dayton Audio DTA-2.1BT2 is a discrete amplifier capable of accompanying two speakers and a subwoofer. This makes it possible to create a...
