The Dayton Audio HTA20 is the perfect solution for enjoying the warm sound of a tube amplifier. With its hybrid design, it combines the vintage sound of tube amplifiers with the modern convenience of semiconductor amplifiers. This allows for a unique blend of both vintage and modern technologies.
Debate often rages over which of the tube amplifiers or the transistor models produces a better listening experience. The HTA20's hybrid design puts an end to this debate by utilizing the best of both worlds.. The amplifier thus uses both the classic design of a class AB architecture while employing tubes in the preamplification circuit.
With a power of 2x15W RMS under 4Ω, the HTA20 is ideal for the integration of a small or medium HiFi system. It also benefits from the convenience of Bluetooth 5.0 connectivity, allowing you to stream and control your music remotely, from a smartphone or tablet for example.
With its two stereo RCA inputs and USB-B port, the Dayton Audio HTA20 is versatile, allowing it to connect to a wide range of source devices. In addition to its speaker terminals, the Dayton Audio HTA20 also features an RCA subwoofer output and a 6.35mm headphone output.
Product type | Amplifier |
Inputs | Bluetooth 5.0 1* USB-B 2* Stereo RCA |
Outputs | Speaker terminals 1* RCA subwoofer output 1* Jack 6.35mm headphone output |
Amplification type | Class AB |
Preamplification | Tubes |
Tubes | 2* 6F1 |
Output power | 2x15W RMS @ 4Ω |
THD | < 0.5% @ 15W RMS |
Minimum speaker impedance | 4Ω |
Total gain | 28dB |
SNR | 75dB |
Frequency response | 20Hz-20kHz (1dB) |
Input sensitivity | 315mV |
Channel separation | 53dB |
Supported sampling rates (USB) | PCM up to 32bit 192kHz |
Supported Bluetooth codecs | SBC, AAC |
Tension d'alimentation | 110-220VAC 50/60Hz |
Consommation en veille | 8W |
Dimensions | 279*165*216mm |
Poids | 1.15kg |
Couleur | Noir |
Package | 1* Dayton Audio HTA20 1* Câble d'alimentation |
Input | USB |
Input | Bluetooth |
Input | RCA |
Output | Jack 6.35mm |
Output | Speaker terminal |
Output | Subwoofer |
Color | Black |
Channel | 2 (Stereo) |
Channel | 2.1 |
Class | Class A / AB |
Amplifier chip | N/A |
Power (W) | 15.0 |
Remote Control | No |
