By buying this product you get 52 loyalty points
The perfect solution for enjoying the warmth of a tube amplifier, the Dayton Audio HTA200 features a hybrid design, combining modernity and vintage. It combines the characteristic sound of vintage tube amplifiers with the modern convenience of solid state amplifiers.
The debate often rages over whether tube or transistor amplifiers produce a better listening experience. The HTA200's hybrid design puts an end to this debate by exploiting the best of both worlds. The amplifier uses both the classic Class AB architecture design while employing tubes in the preamplifier circuitry.
With a power of 2x70W RMS under 4Ω, the HTA200 offers a nice power reserve for the integration of a robust HiFi system. It also benefits from the convenience of Bluetooth 5.0 connectivity, allowing you to stream and control your music remotely, from a smartphone or tablet for example.
With its RCA auxiliary input, phono input and USB-B, optical and coaxial digital inputs, the Dayton Audio HTA200 is versatile, allowing it to be connected to many source devices. In addition to its speaker terminals, the Dayton Audio HTA200 offers a subwoofer output on RCA and a headphone output in 6.35mm jack format.
Product type | Amplifier |
Inputs | Bluetooth 5.0 1* USB-B 1* Optical Toslink 1* Coaxial 1* Stereo RCA (AUX) 1* Stereo RCA (phono input) |
Outputs | Speaker terminals 1* RCA subwoofer output 1* Jack 6.35mm headphone output |
Amplification type | Class AB |
Preamplification | Tube |
Tubes | 2* 13P1P 2* 6H2 2* 6A2 |
Output power | 2x70W RMS @ 4Ω |
THD+N | < 1.5% @ 70W RMS |
Minimum speaker impedance | 4Ω |
Total gain | 29dB |
SNR | 80dB |
Frequency response | 15Hz-20kHz (1dB) |
Input sensitivity | 630mV |
Channel separation | 53dB |
Supported sampling rates (USB) | PCM up to 32bit 192kHz |
Tone control | ±6dB/oct @ 200Hz et 4000Hz |
Supply voltage | 110V 60Hz 220V 50Hz |
Standby consumption | 45W |
Dimensions | 333*318*165mm |
Weight | 7.44kg |
Color | Black |
Package | 1* Dayton Audio HTA200 1* Power cable 1* Bluetooth antenna 1* Remote control |
Input | Optical |
Input | Phono |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Input | RCA |
Output | Jack 6.35mm |
Output | Speaker terminal |
Output | Subwoofer |
Color | Black |
Channel | 2.1 |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | N/A |
Power (W) | 70.0 |
Remote Control | Yes |
